Disc bake adapters
[Closed] Disc bake adapters
6 Users
are disc brake adapters front and rear specific or can you just use them at either end as long as they are right size for the rotor?
Posted : 17/04/2010 12:04 pm
Front and rear specific.
Posted : 17/04/2010 12:07 pm
I've mixed and matched, not sure if one can do that universally.
Posted : 17/04/2010 12:10 pm
They're not front and rear specific, but the same adapter on IS mounts will need a +20mm rotor on the front as opposed to the rear.
Posted : 17/04/2010 12:16 pm
so does that mean I need if I wanted to use a 160mm rear adapter on the front it would require a 180mm rotor, and vice versa, or have a misunderstood?
Posted : 17/04/2010 1:04 pm
Yes That is if the frame and forks are IS mount and the brakes post mount
Posted : 17/04/2010 1:28 pm
Yes - 160mm rr adaptor is basically a 180mm front.
Posted : 17/04/2010 2:46 pm
yes thought you could use front on the rear but need a bigger disc
also worth looking at http://www.singletrackworld.com/forum/topic/unusual-brake-mounting-problem if you looking at front mounts.
Posted : 17/04/2010 3:59 pm
