How dinged does a rim have to be to be problematic with a tubeless setup?
and......
does anyone have a technique a way of straightening minor dingettes??
Cheers.
Adjustable spanner, but as the wall is so low on stans, you may crack the rim (I did).
My rim ran tubeless OK with a lot of dents in it tho.
Aye, it's not actually a Stans rim, its a Sun, but using a Stans No Tubes kit, is what I meant.
It's only a small ding and to be honest not sure yet if it's the cause of my problem. I have had two occasions of the the bead seeming to come away from the rim - in the same place I think. I had a good look at the rim this time before trying again and that's when I found the dingette. I have marked it and will see if I get a similar result again - but it may well be another, as yet unknown, issue.
Never thought about an adjustable - obvious now I think about it - Cheers.
