Dialled Bikes Morni...
[Closed] Dialled Bikes Morning Glory- Tyre clearance?
Hey all,
Just got mine built up (pics will follow when I've got all the mud off it again...)
put on some 2.3 conti verticals, and getting a buzzing sound from behind.. tyre is very close to the lh chainstay-3-5 mm, but still got good clearance the other side. Wheels are Hope xc's, and the rear brake works fine- What is wonky here?
Joe
Posted : 10/02/2011 1:58 pm
Might be that the wheel needs re-dishing? Does it wobble when it rotates?
Posted : 10/02/2011 2:02 pm
Tyre could even be seated badly - let all the air out and unseat the tyre from the rim, and blow it up again...
Posted : 10/02/2011 2:17 pm
Could be, but I can't see any wobble when I spin the wheel..
Posted : 10/02/2011 2:28 pm
Yeah the tyre clearance is not great on the MGs. I went from a prince albert to an MG and found my tyres would no longer fit. I've been running 2.1 Kenda Nevegal which is more like a 2.3 and I think that is as big a tyre as would safely fit. Also been running Maxxis Advantage 2.1s (again bigish for size) with no problems. I'm surprised 2.3 Verticals don't fit though. they are a pretty small 2.3. They were smaller than Nevegals. Dish/True your wheel then try again I reckon.
Posted : 10/02/2011 3:30 pm
Yeah, I have a set of 2.3 Nevegals- they are definitely bigger than the Verticals. Does sound like I'm going to have to get the wheel re- trued..
Posted : 10/02/2011 5:38 pm
Always ran 2.1 max on mine cos of the poor clearance. Ran a big un ont front though ๐Ÿ˜€
Posted : 10/02/2011 6:21 pm
