Daft question - cha...
[Closed] Daft question - changing from square taper to HT2 BB
I bought a cheap used road bike that has a square taper bb fitted (and cheap cranks). I'd like to upgrade the cranks to save a bit of weight and this would probably involve changing to a HT2 bb. It is simply a matter of removing the square taper bb and fitting the BB or could there be fitment issues?
Posted : 31/05/2011 10:53 am
It's that simple.
There may well be cheaper ways of saving weight though, and HT2 is nowhere near as durable as ST.
Posted : 31/05/2011 10:54 am
Yeah, run the square taper until it wears out then change to an HT4 BB.
Posted : 31/05/2011 10:55 am
HT4????
Posted : 31/05/2011 10:56 am
Yep - by the time the ST one wears out Shimano will have retired HT2 & 3 😉
Posted : 31/05/2011 10:58 am
This is a good point. The road bike thing is pretty new to me (but interesting) and I suspect the wheels I've got may well be better candidates for weight saving.
Posted : 31/05/2011 11:03 am
- You will need to get the BB shell "faced" to remove the paint - and allow the bearing cups to sit straight/flush
Posted : 31/05/2011 11:06 am
Worth looking at the whole picture - wheels may well be heavy but new ones may be £££, if transmission is worn then may justify new chainset.
TBH making a bike light by piecemeal replacement of parts is just about the most expnsive way of getting a light bike.
If you like to do everything your supposed/told to do then you will. Otherwise dont bother.
Get some planet x model b wheels and some light tires, this would maybe be the best/cheapest way of saving weight
Posted : 31/05/2011 11:10 am
That's much much more like it. I'd save 300g on the front wheel alone, so probably an overall saving of 6-700g on a pair of wheels 😯 ..... sold 🙂
Posted : 31/05/2011 11:40 am
