A friend 'borrowed' my cooltool about ten years ago...
Might go and search his shed this afternoon!
Another vote for the Topeak Mini 20 - I can't think what else it lacks, apart from a pair of pliers, perhaps, but for the size of a small box of matches, it's tough to beat.
This is my back-pocket kitbag now for mountain biking (USB stick for scale):
[img]
[/img]
...which when opened out looks like this:
[img]
[/img]
This gives me:
[list]
[*]multi-tool, chain link remover etc.[/*]
[*]Pump (CO2 + head - I carry different types depending on the bike[/*]
[*]Puncture repair kit - patches, glue (I like the TipTop kits and the boxes are ace for carrying small bits)[/*]
[*]Chain power-links - 10 and 11 speed[/*]
[*]Spare brake pads[/*]
[/list]
All of that in those two small pouches which fit neatly in my back pocket with a spare tube. Not let me down yet...
Another daft question about the OneUp...what do the people who buy kit to then sell on after a couple of months? (I'm not one of them)
Also, what do you do with trailside adjustments on the headset? (few and far between but still need done at times)
Also, Pedro's tyre levers. The best bar none, a must have imo.
I have no idea, why would you?
But if I sold one of the bikes it was fitted to if I wanted to keep it I could just wack a star nut in and go back to normal
The mini tool in the system has a tool for adjusting the tensioning cap so trail side adjustments should be fine
This I think
Ok, ta...it looks a great idea but I'm just checking all the daft bases are covered.
Merak - Member
I still have one of these, with the pouch! Had it over 20 years!
Check! 🙂 Came with a mag subscription I think & never used in anger!
One thing I heard he other day and got me thinking - I've got a Crank Bros 17...does the chain tool work with 11 sp chains?
CB17 here too for my MTBs (along with a Leatherman mini tool and a leatherman S4 at the moment, used to be a leatherman wave)
I have a Knog one for my commuter, and a park one for my brompton, but don't carry a chain tool on either of those
Unlike mountain bike standards, multitools haven't really changed or improved in the last few years, so what was good 5 years ago is probably still pretty good now
Hexus 2 for me- I did explode one a while back but it was old and I was trying to undo a really stuck bolt so fair enough. The levers are shite but that's no loss, because who uses multitool levers anyway?
I did nearly buy a ratchet rocket to replace that one but it seemed like more stuff to go wrong.
I've never gone for the jumbo all in one McGuiver do everything jobbies, just stuff that works-a decent mini allen key set + take a Park chain tool and a couple of tyre levers.
I've got a Crank Bros 19 and 17, longest lasting bike things I've ever had.
+1 for a minimalist allen key set and a small chain tool -
For a standalone chain tool this is great - 77g according to CRC plus you can lose a bit and make it easier to pack by ditching the "bar" - either on purpose or just lose it like I did - then use a suitable allen key to turn the chain tool.
http://www.chainreactioncycles.com/park-tool-mini-brute-chain-tool-ct-5/rp-prod7843
Annoyingly I have both one of those Park chain tools and a topeak mini-6 in the garage somewhere.... but will probably just buy a second SV-10 for the commuter bike.
Another happy CB m17 user here. My first must be about 10yrs old, plenty of use but still going strong. I've had lezyne and pro ones for other bikes but have ended up replacing them with another, shinier, m17.
My favourite tool combination on a fast road bike (albeit with a not so fast rider) is this:
Scott mini tool: 1mm, 2mm, 3mm, 4mm, 5mm, 6mm and 8mm hex keys, T25, flat and phillips screwdrivers, with magnetic holders at both ends (one inline and the other at 90 degrees)
Finish Line Chain Pup
Total weight - 59g
I really like the Crank Brothers Y16 tool. Its a bit heavier and bulkier than most, but solid.
Find when I am working as a group leader a stronger tool tends to be needed one some bikes that are not quite as well maintained.
The chain tool is as others have said is brilliant.
[url= http://www.wiggle.co.uk/crank-brothers-y-16-multitool/ ]Crank Brothers Y16[/url]
