Crosscheck and CX s...
[Closed] Crosscheck and CX shifter quandary-bar end or DT
[#6586811]
I'm building up a surly Crosscheck and was wondering if anyone has used barend or downtube shifters with any reasonable success off-road. Not full on CX racing, but woodsy/path-y/dare-I-say gravelly type riding.
Do I absoluteley HAVE to have STI to stay alive?
It's just down to budget really as it'll be a 1x9 build. Just after opinions!
Posted : 27/10/2014 11:57 am
I'm running down tube shifters on my Cross Check (both full friction), took it round the Mary Towneley loop a few weeks ago without any problems, before that I had bar ends (2x9 friction front, indexed rear). Took a little while to get used to the DT shifters, but doubt I'll go back now.
Posted : 27/10/2014 12:07 pm
Hmmm thats interesting, do you find you're shifting much?
Posted : 27/10/2014 12:14 pm
It depends what you mean by 'much'... I'll usually change down and spin when I know there's something steep ahead and if it comes as a surprise I'll just get out of the saddle.
Posted : 27/10/2014 12:21 pm
That's kinda what I was thinking, riding with a bit of forethought, rather than how I found I rode my road bike, constantly shifting.
I've seen some SA 3 speed barend shifters going cheaply, might be worth fiddling them into friction only.
Posted : 27/10/2014 1:25 pm
 JoB
if you're not bothered by gear-changing constantly and can anticipate the trail ahead so negating the need for instant panic shifts then bar-end shifters are fine, people were doing it for years before STIs arrived after all
[url= http://www.gevenalle.com/store/products/shifters/ ]Gevenalle[/url] offer a third option
Posted : 27/10/2014 1:37 pm
I have them on my Arkose 2, 1x10. I like a 1x set up with a wide-ratio rear, rarely need more than 2 clicks to hit the right gear and keeping it away from the brake hoods means I shift less - sort of a SS-er attitude but with gears when needed. Also very easy to shift across much of the block in one go. But I wouldn't want them on a close-ratio road bike where I was changing more often.
Posted : 27/10/2014 2:17 pm
I do like the look of those Gevenalle shifters, but look to be a bit spendy, especially compared to normal road levers.
I think I'll go with the bar ends then, though I wonder if that Gevenalle system would be easy to replicate......
Posted : 27/10/2014 5:39 pm
What Jameso said - ''I shift less - sort of a SS-er attitude but with gears when needed.''
I love the bar end shifters on my Disc Trucker. I use it off road a lot.
What I would think about though is adding flared drops like the Salsa Cowbell or something. Gives you a touch more knee room.
Posted : 27/10/2014 5:44 pm
I use down tube shifters on my Cross Check and have never had a problem with them off road. I do however have a leisurely approach when taking the old girl off road. Bar end shifters are fine on flared drops. Used to run some on my Karate Monkey with a Midge bar. Be warned though, bar end shifters on flared drops does create a few width problems on narrow trails and the ability to down shift everytime you whack a branch with the bars.
You could always see if you can get some Pauls Thumbies brackets to fit your bars of choice.
Posted : 27/10/2014 6:36 pm
