Hi all, looking for a bit of advice.
The PF30 bottom bracket (specialized Stout crank) on my specialized fuse needs to be changed, so I was looking at changing the cranks too.
There is a spacer, something like 10mm to 15mm between the outside of the bottom bracket and the crank itself (otherwise the crank would sit too close to the bottom bracket)
Is this something that would come as part of a new crankset?
Posted : 19/07/2020 11:02 am
No, it will be part of the bottom bracket
Posted : 19/07/2020 11:08 am
Thank you!
Posted : 19/07/2020 11:27 am
