I want to reduce the ring on my daughters Beinn20. Its got a 114m crank and 36T ring, interference fit ring (no bolts), but she could really do with 32T or even lower to get up the hills.
A bit of searching has found no short cranks with small ring, any idea how to sort this?...
[url= http://www.highpath.net/highpath/cycles/shorten.html ]Shortened cranks?[/url]
larger rear sprocket?
Thought about a large rear - where do I find a 6 speed screwon cassette with mega ring?
Not sure if this is screw on: http://www.spacycles.co.uk/products.php?plid=m2b32s112p2058&rs=gb&vid=5981
http://www.bdpricebikes.co.uk/cassettes-sprockets/sunrace-6-speed-14-24t-screw-on-freewheel.html
how many teeth do you need?
that might do the trick...would still like to know if there was a way of sorting the crank ring, to give a bit more speed flexibility.
SJScycles do a Shimano crankset at 125mm and some Thorn ones starting at 140mm. These might give you some more options?
