Hi all,
I am about to buy a cove hustler 2008 frame for a build but cannot find anywhere the details of what steerer tube width i need. 1 1/5 or 1 1/8. Does anyone know? i am trying to find forks to buy so they arrive at the same time, but not sure what to get.
Thanks
1 1/8" Great bikes, on my third.
Nice purchase !
There's some frame geometry here:
http://www.silverfish-uk.com/DocumentHandler/10195
Yep - 1-1/8". And it's quite a headtube - machined from a lump of aluminium, so solid as a rock. Get a CK headset in there...it'll last a lifetime.
Cove rated these frames as max fork travel 150mm. They feel brilliant with anything from 120mm up to 160mm in my opinion....
What colour are you getting ?
Rockshox - Sektor, Revelation or Pike depending on budget etc.
I've got 150 Rev's RLT 15MM on my Hustler - great fork for the bang.
[URL= http://i306.photobucket.com/albums/nn267/thedeluded/IMGP0314.jp g" target="_blank">
http://i306.photobucket.com/albums/nn267/thedeluded/IMGP0314.jp g"/> [/IMG][/URL]
Cheers for feedback guys. Pic looks awesome.
Its a white frame. Its built but basic ish in some parts and the forks are broke, so Im already on the hunt for upgrades. Hence the questions. thinking probably £120 ish budget for the forks at this stage so i know i cant get anything epic yet, but it will be enough to get it running and then maybe look for something better at a later stage.
150 revs on mine, ran 130mm marzocchis for a while and still felt good. As above really, there good bikes that will do pretty much everything!
130mm suited mine
does anyone know the steerer tube length, just so i dont buy one thats too short. Cheers
150 Revs on mine too
I had a medium and my fork had a 200mm steerer which allowed for a couple of spacers and the stem.
Ran a 160mm Fox 36 float and a 140mm Pike (old model). Better suited to the Pike for general trail riding.
I ran 150mm Sektors on mine
Brilliant bike
The forks are for sale btw (cheap!)
Dave
140 Revs on mine, had old Pikes on before - you should be able to pick some up for around your budget. Mine is one of the later ones, large and head tube length is ~130mm
Dave, how much are you looking for the forks (inc Post).
Also, thanks all for the info.
£110 posted They're 'used' but in full working order I'll try & sort some pics out tomorrow
Dave
That's why I posted the official frame geometry chart for you - if you've already got your own headset, you can measure the stack height. If your frame comes with headset fitted, ask the previous owner what length steerer they ran and whether they had spacers fitted or not.
Dave - cheers, definitely interested. Are stanctions clean?
Disc jockey - gotcha, im new to the building side so will be full of stupid questions, and mistakes through the build. Right of passage though to build a bike I guess. Been riding 2 years and had ready built bikes before so just tinkered when doing upgrades. Cheers
Good luck with the build, they are great bikes.
Run mine with 150mm revs. Used to have u-turns set to 135mm but now prefer 150mm. Between 130mm and 150mm you'll be fine.
If you decide to go down the dropper post route may want to consider getting the seat tube reamed out to 30.9mm so you can fit a reverb.
Have had 140 Pikes on my 05 Hustler for years, spot on for trail use from The Peaks, North Downs to Whistler. .
Craig
Sending pics in E-mail
Dave
I use fox float (2011) rlc's... great forks i've also rand dt swiss xmm 140's but prefer the fox's.
With a hope headset my steerer is 195mm and takes a 5mm spacer above the stem, stem has a 35mm stack height.
