Could I have someon...
[Closed] Could I have someone fabricate me an alu front triangle?
Would any frame builder do this?
Also, having seen Colin Furze hydroform a motorbike exhaust using a jetwasher, it's making me think about having a go myself.  I won't, obvs, but I might think about it 🙂
Posted : 17/09/2018 3:16 pm
Alu often needs heat treatment for structural purposes which is why small scale frame builders eschew it.
Posted : 17/09/2018 3:20 pm
Might not be too hard to build an oven out of bricks with an electric element inside and a thermostat.
Carbon instead maybe.. hmm.
Posted : 17/09/2018 3:21 pm
Whats wrong with carbon fibre and spoons?
Posted : 17/09/2018 3:22 pm
THEY WEREN'T SPOONS!!!!!!
Regards Colin Furze hydoforming, it'll work for non structural parts (if the welds hold) - but a bike frame, I wouldn't trust that as far as I could........
Posted : 17/09/2018 3:23 pm
hang on.
Something's gone wrong with the sequence of posts and posters on this thread.
They might, but step one is finding a builder who works with Alu.
I've had it done with steel, BTR built me a front end to mate to a Schwinn Lawwill back end, but obviously not all builders will be up for that kind of work, so in a small pool of "builders who would do that kind of thing" you're then looking into the even smaller pool of "and work with Alu".
I can't think of any off the top of my head...
Posted : 17/09/2018 3:29 pm
I can’t think of any off the top of my head…
Frank the Welder or Rock Lobster are the only two that I can think of, both in the States though and I've no idea whether they'd take the work on.
Posted : 17/09/2018 3:38 pm
What are you budgeting for this OP?
Posted : 17/09/2018 3:44 pm
You could ask Orange, they'd do you one with a free swingarm, it might cost as much as a full frame but that's the price you pay for custom. I think they'll limit you to the stock geometry though. 😉
Posted : 17/09/2018 4:05 pm
a lot of hydoformed frames are made from standard tube sections that are then cut and profiled to fit together into the individual customers design. Takes out a lot the cost and you get to choose from standard sections with known dimensions and properties for your CAD and FEA.
Posted : 17/09/2018 4:18 pm
Vernon Barker used to do Alu, fairly sure the guys that have taken over have continued that.
Posted : 17/09/2018 4:20 pm
