Correct Setup for B...
[Closed] Correct Setup for BB installation on 5Spot?
i am installing a CK BB onto my 5Spot which is a 73mm shell.
I am also putting on a BB mounted chain guide and am trying to work out how many spacers i need and on which side.
Do i have one spacer on the non-drive side and only the BB mounted chain guide on the drive side? What determines the amount of spacers?
Posted : 03/07/2010 8:58 pm
I thought with that set up you would have no spacers. I could be wrong tho lol
Posted : 03/07/2010 9:01 pm
 nuke
Could be tricky as per here...
http://www.crankbrothers.com/support/installation_cobalt_bb.php
...it's no spacers for 73mm.
Iirc with 68mm its two spacers drive side one on nondrive with 73mm It's just one on drive side.so if your using bb mount so long as its 2.5mm no spacer needed. I think ๐Ÿ˜‰
Posted : 03/07/2010 9:25 pm
 nuke
[i]Iirc [/i]
You didn't...nor did you click on my link ๐Ÿ˜‰
For a CB BB its no spacers for 73mm.
Posted : 03/07/2010 9:39 pm
I didn't mate as on my phone but he's fitting a Chris king not a crank bros ๐Ÿ˜‰
Posted : 03/07/2010 9:56 pm
 nuke
Facepalm moment ๐Ÿ˜ณ
๐Ÿ˜‰
Posted : 03/07/2010 10:10 pm
in the end it didnt matter anyway as the drive side shell i took out had one of the threads flattened resulting in it being useless.
looks like another new BB for me!!
thats the 2nd time it happened after my LBS had installed a new one for me!! The same thing happened on a hope BB previously......is there a reason for this?
Posted : 03/07/2010 10:30 pm
No spacer on the non driveside and just slot your chainguide in behind the bb cup on the driveside. If your guide is like a stinger then it will be a bit wider than the normal spacers. Shouldn't be a problem and won't really put your chainline out of whack. I run a bb mounted stinger on my 5 Spot with no issues.
Posted : 03/07/2010 10:36 pm
