Convert Rival Dub 2...
Convert Rival Dub 2x to 1x oval chainring?
Hello all, would like to know if it’s possible to convert a Rival AXS D1 crankset which is 2x to use a single 1x oval chainring??
The 2x looks like it uses the 4 bolt spider, I’m unsure if this spider can be removed and then I get a direct mount  oval chain ring like this:
https://uniteco.bike/shop/drivetrain/chainrings/sram-gravel-oval-chainring-standard-6mm/?attribute_pa_colour=silver&attribute_pa_size=44t&gad_source=1&gbraid=0AAAAACdHwirbILVbK7DtPyHo1ogNLt4rP&gclid=EAIaIQobChMIo7ixlu2ohwMVYp1QBh2KZAdSEAQYASABEgJuVfD_BwE
The current 2x crankset has a power meter so want to keep using it rather than replacing outright.
Cheers!
Posted : 15/07/2024 12:50 pm
My GRX Rival 1x had a 4 bolt spider that I replaced with a direct mount chainring.
Which doesn't necessarily help you much...
I guess best way to know would be to take the cranks off quickly and look or look in between bb & chainrings and you might just be able to see how it mounts.
Posted : 15/07/2024 1:41 pm
The AXS stuff is the newer 8 bolt direct mount isn’t it?
Like this-
8 bolt
Posted : 15/07/2024 4:30 pm
