can you get a converter?
Bruce
Look at the problem solvers website.
http://problemsolversbike.com/products/bb30_pressfit_30_adapter_kit/
Out of interest, are BB30 cranks the same as normal HT2 cranks? Or do they have a 30mm axle dia?
there xx bb 30 0nes i just want to run an xtr set up with a single ring
Do you have a pressfit30 or BB30 as it makes a difference which adapters to run?
If you have a PF30 then the Problem Solvers one works best, if you have a BB30 the Wheels MFG is probably better.
The difference is the 2x1.7mm washers with the Problems Solvers adapter as PF30 is 3.4mm wider than BB30 so the washers aren't needed. This link explains it pretty well [url= http://salsacycles.com/culture/building_up_a_spearfish_frame/ ]Salsa Spearfish Build[/url].
If you have a BB30 I have a set of Wheels MFG adapters to sell (I have a PF30 frame) that work with 24mm cranks.
