Convert Hope Pro 2 ...
[Closed] Convert Hope Pro 2 Evo to Bolt through
3 Users
I have some On One wheels which came with a new bike and I want to replace them with Hope Hoops. Though it would be nice to use the rear bolt through axle which came with the bike.
If I want to convert the above to a bolt through. Do I need this or is there something simpler
http://www.jejamescycles.co.uk/hope-pro-2-item145394.html
I notice for the front you just simply pull out some cups and put in a bigger one.
Thanks
Posted : 03/08/2012 5:17 pm
Looks like the simplest solution - geared version of the axle that comes in the SS/trials hub. Doesn't look like you get bolts with that though 🙁
Posted : 03/08/2012 5:48 pm
That's the kit for Pro2, not Evo. All you need is the end caps to suit 10mm bolt through, part no. hub 456 and hub459.(unless you're talking bolt in, in which case you'll need the axle as well, Hub 235)
Posted : 03/08/2012 6:01 pm
Thanks Coatsey. Its a Pro2 Evo. Looks like I just need this.
http://www.wiggle.co.uk/hope-pro-2-evo-mtb-rear-wheel-axle-conversion-kit
Matt
Posted : 04/08/2012 12:08 am
