Convert an older XT...
[Closed] Convert an older XT triple c/set to a double with the new ratios (say 26/38)?
So if the new 'trail' double chainsets from Shimano (XT, SLX) use the same bolt circle diameter as older Shimano chainsets, is it possible to just buy a pair of the chainrings to fit an older set of XT cranks and convert it to a double this way? (the model preceding the latest version)
I'd like to go 26/38, or even 26/36.
Anything to stop me?
Posted : 30/03/2013 9:59 am
I don't think so, it's what I've done and doubtless countless other people. You lose some bigger gear ratios, so anything involving longs flat bits of road get very spinny. But then if you're doing lots of long flat road sections you should perhaps have bought a road bike in the first place.
And having 26t as the granny ring rather than 22t means you'll need to be a bit fitter, and eat fewer pies, to get up [i]really[/i] steep hills. Or get off and walk.
Posted : 30/03/2013 10:26 am
Went 2x10 with my XT 36/26
Bought the rings from someone on here and swapped with my 3x10
To get good shifting though you'll need a 2x10 front mech (my 3x10 was horrific)
Posted : 30/03/2013 10:31 am
Small point to concider, some bikes won't take that gearing, for example an orange 5 won't take 26/38 chainrings.
Posted : 30/03/2013 10:45 am
Interesting. 24/36 works fine on mine.
Posted : 30/03/2013 10:56 am
Oranges official line... All 34 tooth work on all 5's, some 36's on some 5's and no 38's on any... Chain hits the weld when you shift up...
Posted : 30/03/2013 11:32 am
I'm running 22/36 2x9,and bash,with no problems,using old 3x9 front mech and shifter.
Posted : 30/03/2013 11:58 am
Its for a Zesty, I'm currently running 1x10 with the lowest gear being 34 chainring and 36 at the back. Some of this year's Zesty's run 2x10, so I don't think there should be any problems.
Its fine for the UK, but I'm taking it abroad later in the year and if there are longer climbs I think I might want a bit lower gearing.
Posted : 30/03/2013 1:01 pm
