Having just bought my first ever 10 speed bike I am somewhat confused by the joining links on the sram chain. I can't get it apart although it looks like the 9 speed one - does it come apart in the same way by hand or is the tool essential? In practice can they be reused or not? ( I know its not reccomended) ruddy expensive at £7 a replacement if they have to be replaced every time I lube the chain.
Help a confused old luddite please
I've got SRAM and KMC 10 spd chains and i find that both sets of quick links are stiffer than the old 8/9 speed ones.
I use my Knippex adjustable pliers on them if I'm at home. On the trail the might be a bit tricky without a tool.
Afaik it's only 11/12 spd that are not reusable.
The 10 speed Sram links are not designed to be reused. You can get them apart by using a quick link tool or some molgrips. KMC 10 speed links are now re-usable.
can I use kmc quick links on a sram chain?
- I really don't want to go back to using oil on chains so much prefering the boil in the tin wax
You can use 9sp quick links on a 10sp chain no problem.
I've not had any problems reusing them on the same chain, I wouldn't move one over to a new chain or between chains.
A couple of methods:
https://www.youtube.com/watch?v=1GnlOS5Bgn0
Yes
That SRAM video is for powerlinks which they use up to 9spd. The 10spd and above are called powerlock and you'd really struggle to get them apart without tools.
I can open 9sp links easily. 10 speed the same method?
Ta Simon
They join and come apart the same way but are a *lot* tighter. Come apart easily with molgips across the diagonal.
TJ, if you need to undo them out on the trail, a wee section of gear cable is handy, just wrap it round and pull tight and they pop apart.
The 10 speed links work fine on 11 speed chains too.
