... on alpine descents? Given that the best descenders are all former mtbers and that most of us are mtbers. How would we cope if we had to race them(the slowest ones) from the top of say Alpe D'hues to the bottom on the road?
We'd be shit.
You would be a long, long way back.
professional athletes are in a completely different league, to average joes.
You'd be introduced to the concept of eating dust. They'd be measuring your time using a calendar rather than a stopwatch. 😉
muppetWrangler - Member
We'd be shit.
+1
We'd be hopeless.
I've only ever hit over 60mph twice on the bike. These boys do it regularly.
It's all about the size of your balls.
I found going over 50 to be fairly terrifying.
BS they do.
To be fair they do probably ride bigger hills more regularly 🙂
I reckon I could take them in a straight line down hill, but anything needing braking and cornering my weight would be a massive disadvantage.
Depends if there is a coffee/cake shop on the way down.
... although we would all easily be faster than Andy 'Boo Hoo, Pedallling Down a Big French Hill is Really Dangerous' Shrek
Not very well.
These guys are out on the road bikes all day every day tackling those type of descents. They know exactly where the limit of the bike is and hit those kind of speeds a lot of the time.
Hitting 40mph for the first time is scary, then you get use to it. 50 then becomes scary and so on, these guys have gone through that up towards 70mph and will be happy at those kinds of speeds.
Even just looking at the speeds they can put a jacket on with hands off the bars shows how good they are at speed.
Think calling these guys 'bad/poor' descenders is pretty unfair in general terms as they are still pro bike riders.
DISCLAIMER - this is based against normal riders, not the STW riding gods who will, of course, be faster!!
EDIT - I'd be able to freewheel faster than them, weight would be an advantage there - freewheel comp down a straight road I'd probably beat them!
BS they do.
Thor was measured at a 69.6 mph (112 kph) the other day.
BS they do.
They do. Have a look at the shots of the motorbike speedo on some of the descents. Thor Hushovd was clocked at 112kph / 69 mph on his Garmin GPS speedo and everyone else in the Garmin team had speeds of about 100kph (62 mph).
Even I've had speeds of 60mph in the French Alps and I was still being overtaken by local roadies (who obviously knew the descent far better than I did). 50's mph was more common for me but the pros will easily hit 60+ for short periods of time on a regular basis.
[i]Depends if there is a coffee/cake shop on the way down[/i]
I think you'd find that there is a huge range on "elevated" abilities in the pro peloton and a huge range of "moderate" ability with STW riders. There will be some overlap.
That's one occasion on one descent. Hardly regular - most of the hills aren't steep enough for that.
I would nail them all to the floor with my speed and my grace.
8)
The first time I decended down a Dolomite I pooped myself. It was the Pasa De Gavia and I hit speeds of 80ks which at the time was the fastest ever I'd been on a bike. Since then I've done many more "bumps" over that way and regularly hit 80ks.
To be fair though I've also been shot down the road a few times too, notably last year when I spent 4weeks in traction having missjudged a sharpie and full on 20mtr skid (no fixie content) into barrier/down ravine moment.. bike was shot to pieces, I've the scars on my left thigh still..and the road wasn't shut at the time either.
I consider myself a LuckyBoy, a LuckyBoy I am.
So, unless you're willing to practice hacking off the top, it'll poop you out sonny.
Think you might need to check Newton's Second Law of Motion!EDIT - I'd be able to freewheel faster than them, weight would be an advantage there - freewheel comp down a straight road I'd probably beat them!
Being heavier will not make any difference, presuming the road is smooth. If anything, being bigger will give you more drag and make you slower.
"LAST ONE TO THE BOTTOM"S GETTIN' THE BEERS IN!!!!"
That should do it 🙂
A few of us (not me, I hasten to add!), the ones with natural DH talent, would be ok but most of us would get thrashed. I doubt that anyone here would be anywhere near able to keep up with the best guys.
Appealing to Newton's laws of motion suggests you've not heard of aero drag. Your second bit suggests you don't understand how aero drag works.
glenp - Member
Think you might need to check Newton's Second Law of Motion!Being heavier will not make any difference, presuming the road is smooth. If anything, being bigger will give you more drag and make you slower.
Wrong 🙂
Ask any tall/heavy road racer and they'll tell you that descending at speed in a road race in a group is quite tricky as you naturally descend faster than the little lads so you end up constantly on the brakes.
Why? Wind resistance - bigger riders' weight goes up significantly more relative to the added drag from increased size. End result, more gravitational force to speed up the rider with relatively less increase in drag to slow them down = more speed overall.
I might not be quicker but I'd do it with more of a smile on my face and a lot less whinging than some.
errr, no heavier objects fall faster, anyone who's done A-level physics, thought about it, then ignored the sylabus as it talks a lot about droping a sack of feathers and a sack of coal in a vacuum. Add in air resistance and heavy stuff falls faster.
One of the reasons tandem parachuters/skydivers have those little 'chutes out fromthe start that slow them down to about the same speed as solo skydivers.
I'd be great in a straight line, crap in corners. Just like my mountain biking.
Well I recorded an average speed of over 64mph over about 30 miles the other day according to a GPS thingy so I'd naturally beat everyone! 😆
There'd be more chance in you covering them with your liquid poo, Bully...
I've no problem with the claimed speeds these guys reach.
I managed 52 mph on my road bike, but had to slow back down as I ran out of hill. That wouldn't be a problem in the big mountains.
Those guys are proper nails though, I'd back off long before they did!
most i've done is 41mph on the road with my mtb, so i reckon pretty useless!
Bit of a physics fail, there. They've even performed the experiment on the moon, the feather and the coal fall at the same rate. Big things will naturally go slower as they offer more air resistance.
That's probably more to do with stabilising a complex shape than any kind of weight issue.
If anyone on here thinks they'd keep up with any of the pros, they're deluding themselves.
I could freewheel downhill a lot faster than most of them, if not all but then I've got a good few kilos on them 🙂 I might have issues keeping up round the bends 🙂
Interestingly, Harmon on Eurosport keeps pointing out when ex-mountain bikers are descending well and thinks there's a link.
So given a good few alpine road descents to get our teeth stuck into, maybe we'd be ok (well better than Andy Schleck anyway).
The way i look at it is,i could decend faster and better than they could erect a conservatory,therefor i'm better than them.
All depends if you descend well for an mtber. Most of the riders I encounter are **** awful on an mtb. Why this would make them good on the road I don't know.
I follow the rules with my descending ability.
Rule #64 - Cornering confidence increases with time and experience.This pattern continues until it falls sharply and suddenly.
When I'm at my peak (therefore about to crash), I feel like I'm pretty quick, and can drop average club riders pretty easily. I still rarely go over 40mph though, and don't think I've ever done 50mph. But I'd get ragged by the pros, I just don't have the straight line high speed confidence you need.
I would leave them gasping and astonished in a cloud of dust.. even if I was riding a unicycle..
fact
Also on descents like that you have to take into account of acceleration out of corners, every corner which takes alot out of you and also pedalling upto a speed where freewheeling is more aero which is where pro's make up time
I suppose it must depend on where you ride and the type of riding you do to a certain extent. I clock 45+mph (50 on a good day) on my commute home across the Quantocks and don't think a lot of it (apart from when it's raining and dark) If I ride an alternate route 60+mph is easily possible.
Having almost no experience on a road bike I would either drag my brakes like a BGB the whole way down or crash horribly at the first bend
Slow, that's how we'd compare. Compared to a pro like Sean Yates, absolutely glacial.
I've ridden a couple of descents in the Alps after seeing the pros do it. I thought I was quick on a road bike going downhill till I saw how they leant into and accelerated out of corners.
Would not even want to try on tyres not much wider than a gnats chuff,rim brakes and that awfull hunched riding position (probably shit myself)
Give me 2.4 tyres, 180mm disc brakes,710mm bars and a nice comfortable sat up riding position any day of the week
😆 @ Dibs comparing the quantocks to an alpine road descent 😆
I'm a pretty compitent descender/cornerer on an mtb and have descended tour route roads in both the Alps and Pyranees and know fine I couldn't keep up with pro roadies on a long road descent even if they freewheeled the entire thing.
yunki - MemberI would leave them gasping and astonished in a cloud of dust..
Me too- after going straight on in the first corner. "Why did he do that?" they'll gasp in astonishment as they ride through a cloud of dust.
Is it wrong that I much prefer a fast road descent that a mtb descent?
I think most of us would be pants to be honest, those guys are on the edge and thats all they do, great footage today on Eurosport would have loved to have ridden over that course, obviously somewhat slower than the pros and probably stopping off in that guys driveway for a rest or to let the brakes cool off.
I've never gotten scared when descending, not even when i was tucked at 50mph. I even tried to spin to go faster but my legs wouldn't go fast enough.
Yes, the Quantocks are the only area in the Uk that can adequately prepare you for an Alpine descent.
as most on here have more gravity acting on them they would both go faster and bounce further on crashing 😉
Me i would be scared about 50 mph ish and back off so would get dropped quite quickly.
I regularly hit 50mph (road bike) on a particular hill near here. It's a pretty straight, wide and smooth main road. A few mph over 50 is about as fast as I can physically spin with 52/11. Do they fit 53's for the mountain stages?
I have to say when I top out and stop putting in effort and start thinking about what i'm doing, I look at my skinny little tyres and think ooooooh sh!t. . . .
In the vid clip above the guys are freewheeling at 100km/h and touching each others bums ffs!
I rode down Alpe D' Huez (before I rode up it) and it was pretty cool. But . . . the corners are sharp, the tarmac is smoooooth and the drop is steep. You can big-ring it out the corners and your at 40mph in seconds - just as the next bend appears.
On a technical descent like todays I would have ridden into that guys carpark, through the wall and off down the mountain . . . . never to be seen again!
EDIT: It must help knowing for sure that nothing is gonna come round a bend towards you too??
Quantocks vs The Tour
I think Cothelstone hill was classified grade 2 in a recent Tour of Britain. Obviously much shorter though.
I've peaked ~45 mpg down Bristol Hill into Wells on my Charge Tap road bike, and it was fun as the bends are quite gentle. Cheddar Gorge has some steep bends and is much more worrying. I'd be terrified on a skippy racing bike. No way I'd want to go much faster.
Also when I crash I tend to lie there for a while, eventually get up, brush myself down, check the bikes ok, check I'm ok, moan a little, make up an excuse as to what caused me to crash (obviously wasn't my fault), then maybe get back on the bike and pootle off back down the hill, taking it easy.
They don't tend to do that in the TdF - or at least the cameras don't show it.
Re the Physics - air resistance is proportional to the frontal AREA of a rider, gravitational acceleration is proportional to the mass which is proportional to the VOLUME of a rider*.
Area increases as the square of linear dimensions (aka 'size')
Volume increases as the cube of linear dimensions.
So a rider twice as tall would have four times the wind resistance and nine times the gravity assist downhill.
* assuming equal density.
That guy on the yellow bike was incredible.
Loved the way he was out of the saddle sprinting, where I'd be braking. 😀
I have two points to make 1:ex mtbers are better descenders my arse and secondly most people on here talk complete shite about anything relating to road riding.
YOU WOULD ALL BE SHIT COMPARED TO THEM ALL end of story
Careful now, things of different masses will roll down the hill in the same time. It's just the ratio of mass to surface area that causes heavier riders to go quicker.
I think.
Yep. Done this many, many times. Everything's fine until I start thinking about it.
Incidentally the fastest I've ever done was around the quantocks too, 'fraid I don't know the hill as I was being guided around by a mate but I did have a speed wobble on the fastest section which does focus the mind a little. It was a long time ago but I think the speed was in the low 50's mph, certainly not topped it since, best I can get to locally is about 50 kph.
FTFY 😉RealMan - Member
Also [s]when I crash I tend to lie there for a while, eventually get up, brush myself down, check the bikes ok, check I'm ok, moan a little, make up an excuse as to what caused me to crash (obviously wasn't my fault), then maybe get back on the bike and pootle off back down the hill, taking it easy.They don't tend to do that in the TdF - or at least the cameras don't show it.[/s]not only am I shit, I'm also a bit of a pussy.
Are we allowed to use hydraulic discs? Because as we've all agreed in previous posts, they'd be better on road bikes.
thats why the MTb'er who won this was running discs, oh wait...
Thank you GW 😆
C.Boardman, I think, attributed Cadel's excellent descent yesterday to his mountain bike skills, since Cadel won two XC world cup races prior converting to road. And since Boardman is an ex World Champion himself, I'd be concerned about your arse 😉
I've decended Alpe D'Huez twice, once just getting a lift up to ride down. Didn't have a speedo but on the only section where you could go really quick was over 60+ as left the car for dead. The speed didn't bother me being a ski racer at the time, if any thing wanted to.go quicker.
Pros would be quicker as they can accelerate out of corners quicker.
For me, it's a combination of the traffic and the road surface that makes a descent scary (or scarier). The first few rides on carbon forks were an eye opener too! 😯
I'm not keen on the tendency locally to repair worn out roads by spraying 15-20mm chippings onto tar - that's really horrible to ride on, and it ruts quickly from being compacted by traffic (not deeply it must be said, but riding on 25's you don't have much to play with). Anyway, all that aside, I'm in the 'I'd be crap' camp.
FunkyDunc is that kmh or mph?
I'd really like to see someone hit 60/100 on the Alpe straights are just not long enough IMO I'm not saying you didn't do it - but it would be a stellar performance
(I would not rely on cars as they do not do 100kph down the Alpe)
It's incredibly hard to get over 52ish mph on a road bike - the aerodynamics are so against it - and the gradients are really not that steep in France as the roads are so well made.
That 112kph of Thors the other day is an exceptional speed, he is a big guy, with exceptional skills - even among the elite descenders.
The MTB rider makes better descender line is BS when comparing pro roadies - what does A Schleck do in the off season - and The Chicken was ex MTB and his bike handling was a joke.
And roadies bike handling is much better than MTBers give them credit for - when I crossed over I was expecting to be embarassed but now I've been doing it for a bit think most riders are crap as well as slow and unfit. Obviously there are exceptions... That said my road bike descending has improved a lot since coming over, but I attribute a lot of that to jedi's coaching
Hmm that WOUld have ben beter wiv raNdom CAPs and no grammer
Anyway those of you that really have done 60mph on a road bike - I salute you
Buzz-lightyear - Cadel didnt win two world cup races - it was two world cup series that he won.
Yes of course we would be shite but I think the relative position still exists further down the food chain. When I go out with my roadie mates several of whom are good triathletes, they thrash me into tiny pieces on the climbs but on the downs they are like a pensioners bingo outing. They do realise this and are taking lessons from a motorbike racer in an attempt to go down faster [oops]. Unfortunately the time I lose flogging up a big long climb is far more than they lose going down, still it's nice to be in front once or twice a day.
PS wouldn't disc brakes allow everybody to descend faster?
Careful now, things of different masses will roll down the hill in the same time. It's just the ratio of mass to surface area that causes heavier riders to go quicker.I think
That's what I am saying. Taking arbirtary units, that ratio would be 1:1 in any given rider, and 4:9 in a rider twice the height.
I have peaked at 55mph riding off the Mendips on a tt bike with tri bars using 55x11. The fastest I have done was 60mph coming off Dartmoor after the finish of the Devil Audax
We'd be rubbish and slow, just like trying to keep up with Cav on the climbs, he'd still hand you your ass
Mph. The first few bends down have reasonable straights before the next village bit.
You can get 60 mph down a small hill in to Otley, Leeds too its not really the length that matters its the steepness and getting speed up quick.
Re the Physics
Lets put two rider with the same bike at the top of the same hill.
With no air resitance, the only work they receive is the work of gravity:
for rider one:
1/2m1*Vendofthehil²=m1*g*height of the hill
for rider two:
1/2m2*Vendofthehil²=m2*g*height of the hill
As you can see you can remove the weight in both equation, therefore they will it the bottom at the same speed.
Now perform this on earth you must add wind resistance: F 1/2*S*C*V².
so for rider one:
1/2m1*Vendofthehil²=m1*g*heightofthehill-1/2*S*C*V²
and for rider 2
1/2m2*Vendofthehil²=m2*g*heightofthehill-1/2*S*C*V²
Which arise the question, whom, of the two rider has the biggest S*C coeff 😉
I have done one big alpine pass. I was descending at 50 ish mph in places, these guys do 70 mphish.
None of us could get close to them
well Chris Bordman is talking out of his arse as the two skills are very very different. Was Lance MTBer first? Was Salvodeli, Hushovd, Spartacus? Cadel is a good descender because he has those skills and no doubt works at them having been a top mtber has no influence on it at all. Millar was a BMX racer and mtber in his youth and was shocked by the speed of the descending in the pro races.
Its just a lazy line that presenters use.
