polished aluminium ...
[Closed] polished aluminium frames
[#2965556]
forgive my complete ignorance, but I have a polished rear triangle on my aluminium turner 5 spot. Is this polished effect literally caused by polishing raw aluminium, of is it a plated effect? secondly, is it coated with anything to stop it fading/protection?
Reason i ask is I'm doing a refurb and wanted to know what to do with it. Thanks in advance
Posted : 20/07/2011 1:56 pm
polished bare metal with a laquer coating normally for aluminium.
Posted : 20/07/2011 1:59 pm
5spot rear is polished alli with a clear anodizing coat for long lasting protection.
Posted : 20/07/2011 2:23 pm
brilliants, thanks guys- if in areas its looking rather tired/discoloured I presume the anodising coat had deteriorated?
Posted : 20/07/2011 3:20 pm
ye-es, something like that, with presumably a layer of oxidisation underneath. It's not damaging (like rust), IIRC, it just happens quite quickly.
Posted : 20/07/2011 3:56 pm
I doubt anodising would leave a polished finish as it involves etching away a micro layer of material...
The rear ends on Turners look very simillar to Ventana, & it is literally acheived by polishing the raw allow with increasingly fine grades of polishing mops & abrasive soap. Turner & Ventana sprouted from the same outfit way way back, from what I can remember...
If you polish it it will retain a shine quite well. [url= http://stores.ebay.co.uk/polishingkitsandaccessories ]The place I bought my polishing kit from[/url] recomended a polish called Belgom Alu, & it seems to work. Mine hasnt lost any shine in the month since I did it.
You could polish it then lacquer it. It will lose a bit of shine, but should stay nice....until the lacquer is all chipped & scratched that is.
Just give it a polish & leave it...
Posted : 20/07/2011 4:17 pm
thanks, tak, is your frame painting chap in burton on trent, incase you dont see my question in the other post?
Posted : 20/07/2011 4:32 pm
yes mate.
Posted : 20/07/2011 4:40 pm
I used to ride Manitou frames, they came with a sticker that said the polished finish was protected by anodizing and should only be washed with mild soap and water. Nothing abrasive or chemical. A mirror finish can be achieved under anodizing.
Posted : 20/07/2011 4:43 pm
[url= http://farm7.static.flickr.com/6129/5958332803_c79d895695_z.jp g" target="_blank">http://farm7.static.flickr.com/6129/5958332803_c79d895695_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/5958332803/ ]IMG_1394[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
[url= http://farm7.static.flickr.com/6022/5958887488_e608436f83_z.jp g" target="_blank">http://farm7.static.flickr.com/6022/5958887488_e608436f83_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/takisawa2/5958887488/ ]IMG_1392[/url] by [url= http://www.flickr.com/people/takisawa2/ ]pten2106[/url], on Flickr
Posted : 20/07/2011 8:59 pm
