Commencal Meta v4 w...
[Closed] Commencal Meta v4 with a 150mm dropper?
Is anyone running this combination? Im going to measure properly later, but I think the interrupted seat tube is going to leave too much seat post showing for me.
I think if any post is going to work then it's going to be a Reverb, possibly with the Connectamajig removed.
Posted : 03/02/2018 10:56 am
Just measure it all an drop a non dropper in to see how far it goes down?
Posted : 03/02/2018 10:57 am
I have a 150mm reverb stealth on my Large v4 and it's possible to fully insert it into the frame.
Posted : 03/02/2018 11:19 am
How about considering the bikeyoke revive? The 160 dropper has quite a short overall length.
Posted : 03/02/2018 11:27 am
Thanks Finkill - yep, Commencal fit a 150 as standard on large, but I think it will be tight in a medium.ย  The suspension pivot isnt a complete block in the tube (obviously - it's Stealth....) but I had issues showing a 125mm post into a small Meta frame, it's easy to crush / kink the hose and cause issues with the post's activation.ย  That's also why I would remove the Connectamajig I think.
The Bikeyoke one looks interesting - I assume "non-servicable" is to be read as a positive?!ย  But there are some good offers on B1 Reverbs with the new remote around at the moment too.
Posted : 03/02/2018 11:48 am
