Commencal furious o...
[Closed] Commencal furious owners:can you run a 180mm rear rotor?
hello,
if you have owned or have a commencal furious.of the top of your head can you run a 180mm rear rotor?
as the frame has post mount/direct mount its hard to tell if you can run a smaller rotor?
cant find difinitivly if you can or cant
many thanks
Posted : 01/09/2015 10:25 am
 mc
Smallest is 200mm.
IIRC, a standard rear post mount should be 180mm, however the furious had the mount moved out so the smallest possible was 200mm. I certainly ran Hope V2s on mine, and the rear was 200 without any adapters.
Posted : 01/09/2015 11:30 am
Ditto above.
You can only run 200mm. I also ran V2's on mine
Posted : 01/09/2015 11:39 am
perfect!scrubs the idea of haing the spare 180 i had.As much as i assumed from photos but nice to have it confirmed thankyou gents!
Posted : 01/09/2015 1:52 pm
