Comfy bar grips for...
[Closed] Comfy bar grips for 24 hour riding...?
I'm doing the Bearbones200 next month, would foam grips be worth a try.
I've got a carbon joint replacement in one of my fingers (Mmmm carbon!) and as such try to look for larger diameter and comfortable grips.
Any suggestions?
Posted : 01/09/2015 6:13 pm
I'll be doing the same with ESI silicone or similar. Wiggle and superstar do their own brand silicone grips that aren't a million miles away.
Posted : 01/09/2015 6:35 pm
ESI Chunky Silicone, expensive for what they are but worth it IMO. Superstar also do a version and are quite thick too. The silicone works a lot better than regular foam. I've had some success with the Ergon type too, again Superstar do a version and I found them very comfortable, the only negative was I think I lost a bit of control with them.
Posted : 01/09/2015 6:36 pm
ESI Chunky - just fitting mine now. How do you work out where the thinner bit is ? It looks the same thickness all the way around ?
Posted : 01/09/2015 6:49 pm
ESI chunky with good gloves.
Posted : 01/09/2015 6:58 pm
emkay, do you have ESI Chunky or Contour? I think its only the contour that has a thinner section. I've also heard (read on a forum) that the lock on silicone grips aren't as good as the cartridge bit replaces some of the comfy silicone with the hard plastic sleeve of the lock on.
Posted : 01/09/2015 7:57 pm
Ergon?
Chunky plus the palm bit spreads the load too.
Posted : 01/09/2015 7:58 pm
