Comfy 780mm bars
[Closed] Comfy 780mm bars
37 Users
I'm after a pair of 780mm risers that aren't as stiff as a very stiff thing that leaves the hands stinging at the end of a ride. Any ideas?
Posted : 15/12/2016 5:39 pm
I like the Raceface SixC ones for a nice balance of control and damping.
Posted : 15/12/2016 5:43 pm
 qtip
+1 for the SixC bars
Posted : 15/12/2016 6:08 pm
I'm pretty happy with my Renthal Fat Bar, but I've not had any other carbon bar to compare it to.
Some people recommended the Spank Vibrocore ones, but I'm not sure what sizes they come in.
Posted : 15/12/2016 7:38 pm
i think vibrocore come in 780, or 777 at least.
comfiest i've had out of not many are Gravity light (fsa) ones, carbon wrapped ali. had some straight carbon from carbon cycles, not comfy!
Posted : 15/12/2016 7:46 pm
Stooge moto bars are fabulous. 800 wide, just trim if needed
Posted : 15/12/2016 7:47 pm
Well, they seem comfy to me.
Love my RSP carbon Ego bars. Have two pairs now. Light, cheap, comfy...pick three.
Posted : 15/12/2016 7:55 pm
Crank Brothers Cobalt 11 is very, very soft, you can see it bend just in normal use. It does affect control a little, you're definitely less directly connected to the wheel, though not in a way that bothers me at all. I'd be surprised if bars get much softer or comfier
(I replaced an RSP Ego- a fairly typical carbon bar, not especially stiff... And I went from having busted hands after a 3 minute descent, to doing a 7 hour XC race without a twinge, it's fairly ridiculous.)
Posted : 15/12/2016 8:01 pm
Syntave vector carbons are the comfiest Ive tried, theres a twang too them and you can see them flex.
Posted : 15/12/2016 8:34 pm
Not sure if they are "soft" and don't really have much to compare them against, but running a set of Chromag Cutlas bars on my rigid singlespeed at the moment and they are a great shape, and do seem to take a bit of buzz out of the trails.
Posted : 15/12/2016 8:41 pm
Went through few sets last year trying to find one I liked and settled on an aluminium Renthal fat bar. Superstar was good, Spank was the wrong shape, carbon Renthal was waaaaay to stiff and gave me arm pump which surprised me. I just wish the ali fat bars came in black.
Posted : 15/12/2016 9:50 pm
 BigR
I also rate the RSP ergo. Switched out the Salsa bars on my rigid Surly Pugsley and now much more comfy. Also <£50 at Tredz with a voucher.
Posted : 15/12/2016 11:05 pm
Unfashionable on-one knuckleballs are ace.
Posted : 16/12/2016 12:31 am
Burgtec 800s seem a lot less stiff than the 780 Renthals I had previously. More back sweep too, so a little comfier for me anyway
Posted : 16/12/2016 12:35 am
I've been through a few bars in my HT this year trying to get something that doesn't kill my hands.
Started off with a SixC carbon bar but thought it was way too stiff. Then tried a Spank Vibrocore which was better but an odd shape and am now back on Answer Pro Taper DH bars. I like the shape plus they seem quite skinny (they taper quickly from the stem) which means they flex and don't kill my hands / arms.
Posted : 16/12/2016 6:50 am
+1 Syntace Vector carbon. Not cheap but all you need.
Posted : 16/12/2016 7:17 am
 ton
easiest way to make bars comfy, is to use the correct size for your shoulder width. and I have yet to meet a man with 800mm wide shoulders............. 😀
Posted : 16/12/2016 8:46 am
sure, for road riding.
Posted : 16/12/2016 8:57 am
That's fortunate because I don't believe anyone sells 1000mm+ bars! 😉
In more recent years I've used 670, 710, 740, 760, & 800mm bars. Actually the 740 and 800mm bars have single lock-on grips so they're 750 and 810 wide in practice. The comfiest bars are the 810mm ones. 750 are fine but not quite as good. 710 and narrower give a weird shoulder/arm position.
Posted : 16/12/2016 9:00 am
Anyone got any experience of Chromag BZA Carbon 35s? Got a feeling they'll be horribly stiff, but tempted by a set.
Posted : 16/12/2016 9:31 am
 momo
ton - Member
Rubbish, yes that works for drop bars where your elbows are inline but not mtb bars. put your hands flat on a desk with your elbows comfortably bent and see how far apart your hands are, I've just done it and my ring fingers were 720mm apart, so fit perfectly on the 800mm bars on my bike (I run 44cm drops on the roadie which does match the width of my shoulders - I've just measured them)
Posted : 16/12/2016 9:40 am
I just did that. They were comfiest touching each other in the middle.
Posted : 16/12/2016 9:45 am
 ton
so you are saying that a man who runs a 440cm road bar needs a 800mm mtb bar?
I hope you are not saying that. if you are you are a deluded fool.
Posted : 16/12/2016 9:46 am
I don't ride road bikes but I do know that the body position is completely different to MTBs.
If I tuck my shoulder blades in and down and draw my arms back into a strong riding position (similar to a benchpress / push-up position) my hands end up more than door width apart. That's the best width for riding a bike fast downhill if the trees are far enough apart.
If you want to ride your MTB like a road bike then by all means use a narrower bar if you want.
Posted : 16/12/2016 9:59 am
 ton
I use 710mm bars, which a just wider than my shoulders. and I am quite wide across the shoulder. like nearly double the width of most blokes.
I bet you wear all the latest 'nduro' stuff too don't you?
fashion eh........... 😆
Posted : 16/12/2016 10:03 am
Could people not just, you know, help with the question, rather than having to be 'right'?
I've got narrow shoulders and much prefer a wider bar to a narrower one. Horses for courses.
Posted : 16/12/2016 10:10 am
Like my Joystick 35mm Carbon bars
Posted : 16/12/2016 10:11 am
 ton
I agree. sorry for my grumpy old bastard input.
use whatever bars you want.
renthals were always good when I used them. 😀
Posted : 16/12/2016 10:15 am
I can't say I've ever noticed a difference in stiffness between bars. Alloy, steel, carbon. They're just bars to me. 😕
Arm pump is surely more affected by your riding position, bar/stem set up and how relaxed or not your arms are.
Hand cramp - better grips.
Posted : 16/12/2016 10:21 am
Rachel Atherton has much narrower shoulders than you or me, has been unbeaten for almost two years and uses 800mm bars. Fashion?
I usually ride in old Helly Hansens and my shorts are black, not day-glo. My bikes do have sub 65 deg head angles though! 😛
Posted : 16/12/2016 10:25 am
That
Posted : 16/12/2016 10:33 am
Knuckleballs are good in the Chewy version but those are only 750mm I think (ive not tried the wider hard version).
Personally though, [b]Spank Vibrocore[/b]. Such a good bar overlooked because its not carbon. After a week in Morzine this summer, with its baked in braking bumps, my hands were so much better shape compared to previous years with Easton or renthal bars.
Posted : 16/12/2016 10:41 am
Superstar Lithium carbon bars are very good, but they are rarely in stock.
Feel free to drop me a line if you're interested in buying a used one.
Posted : 16/12/2016 10:43 am
I have, they are good
Posted : 16/12/2016 10:51 am
To the OP:
What are you currently using?
How long is your ride? Is it time or distance that is the problem?
Is your bike set up correctly?
I'd look at the last one first - getting your bike set up. I would get numb little and ring fingers on long rides (by long I mean 150Km or more), fine up to 100Km then increasingly sore. I eventually sorted it but it took a while as I'd only change one thing at a time and it would also take a week or more for the numbness/tingling to stop. I now ride a rigid bike and still don't get any problems.
Posted : 16/12/2016 10:54 am
 poah
Spank spike vibrocore user here too. Much better than any carbon bars I've used.
Posted : 18/12/2016 10:12 pm
I've been interested in the vibrocore bars for a while. Any of you who own them able to tell me whether the logo could be easily removed or is it lacquered in to the bar?
Posted : 18/12/2016 10:31 pm
Dead easy... Its all in the angles. [url= http://http://www.charliethebikemonger.com/stooge-moto-bar-11176-p.asp ]stooge moto bars[/url]
Posted : 18/12/2016 11:26 pm
groundskeeperwilly - Member
I have 2 pairs of the Race Team bars with massive yellow logos. You might be able to get the graphics off with nail polish remover of some other solvent but they seem pretty well adhered. I just covered it with some electrical tape, not to obtrusive that you notice immediately.
charlie the bikemonger - Member
Dead easy... Its all in the angles. stooge moto bars
The right sweep can certainly help, but something like vibrocore makes an alu bar much more comfortable. I wish they sold it as something you could add to any bar. I can imagine it would have an amazing impact on road or CX bars.
Sweep is very personal though. Ive tried all sorts of fancy swept bars and hated all of them, midge, Jones, Titec-jones-copies, marys, woodchippers, 11* salsas. Basically my wrists dont like being anything other than straight. 9* sweep is about the most my wrists can be comfortable at, as despite being 6ft4 and wide shouldered my elbows tend to stay tucked in, adding sweep strains my wirst at an angle it doesn't want to be at or pushes my elbows into my ribs. I wish they did work for me, it wasn't cheap to try them all only to get numb hands, sore wrists or strained elbows.
What has really improved my technical riding is wide bars which move my arms away from my sides, and longer reach bikes to let me move backward and forwards on the bike. I can still be comfortable on narrow bars fine as long as they have very little sweep to keep my elbows out, but its harder to ride technical stuff so overall comfort can suffer. Road/cx bars are fine as the hand rotates to vertical to hold the hoods or drops, its a different bend of the wrist.
Posted : 19/12/2016 9:09 am
Charlie your link isn't working and stop mentioning moto bars and Jones's, I'm skint and it's making me grumpy.
Posted : 19/12/2016 9:22 am
Thomson very very stiff indeed but not too harsh if you only hold on for 3 minutes at a time. Lovely direct feel like they're bolted to the front axle but maybe a bit too much feedback for some
Chromag OXS IN BLACK CHROME WOHHHHHHHHHHHHHH way more forgiving without feeling springy
RF Atlas somewhere between the two
Renthal alloy more like the Thomsons but slightly less hardcore
Posted : 19/12/2016 9:23 am
thanks STATO - wish they did a stealth version really. Tape would be my fallback option if the logo can't be easily removed!
Posted : 19/12/2016 4:07 pm
Northwind - Member
Second this.
Posted : 19/12/2016 4:10 pm
Daffy & Northwind - are they the Carbon Cobalt 11 bars? Seem hard to find, especially in 780mm width!
Posted : 19/12/2016 6:41 pm
 poah
that will just look nasty. The decals are hardly intrusive.
Posted : 20/12/2016 9:17 am
I got mine from CRC but I see they're out of stock now. Probably a bit of a niche too far tbh
(I think Daffy might have a set to sell?)
Posted : 20/12/2016 9:28 am
poah - Member
er... is this subtle is it?
[img] ?bg=6E6D69[/img]
Posted : 20/12/2016 9:47 am
My Spank bars had white logos so weren't so bad, but they are a bit lary.
Posted : 20/12/2016 10:06 am
I don't know how to get decals off carbon bars but I was thrilled to discover that nail varnish remover removes the printing from anodised aluminium bars with very little effort. It looked rather strange having two bikes that were almost totally stealth apart from lairy bar graphics.
Posted : 20/12/2016 10:12 am
 poah
I said hardly intrusive (mine are white) - personally I don't look at the front of the bars when I ride and even the yellow ones are fine. My bro in law has the yellow ones on his patrol.
Posted : 20/12/2016 11:40 am
I suppose if the rest of your bike is covered in logos they may not be as in your face, but even on my yellow and black nukeproof those graphics are very noticeable when looking at the bike. Well applied tape solves it and is un-noticeable unless you know to look for it (if you trimmed it tight it would look like matt graphics). There is a still a lairy yellow SPANK logo on the back-side of the bars so, like specializeds, you will never forget what you are riding 😀 .
Posted : 20/12/2016 12:08 pm
 poah
it just doesn't bother me that there is white decals on the bar even more so when I'm riding and concentrating on the trail - I'd see the tape on mine and it would look ****.
Posted : 20/12/2016 12:32 pm
Id be too distracted by the big flap of rear brake hose to see any tape 😆 Nice bike though.
Anyway, they are good bars and the OP should buy them.
Posted : 20/12/2016 12:39 pm
 poah
its the mech hose 😛
my estimation of how much slack I needed at the bottom bracket was slightly off 🙁
Posted : 20/12/2016 12:54 pm
Has anyone tried the Exotic Cycles carbon bars,available from 780-840mm,£59:99?
Posted : 20/12/2016 1:30 pm
840mm 😯
Anyone who has tried them is probably still wedged between two trees out in the woods.
Posted : 20/12/2016 1:55 pm
Knuckleball +1, can't fault them. You just have to be patient and wait till they're 30 quid.
Which could be either anytime, never, or somewhere between.
Posted : 20/12/2016 2:13 pm
 Alex
I have the Vibrocore on my HT and FS. I wanted to try some 800mm bars so removed a set of RF SixC from one bike and set of the crank bro NW is talking about from another (which if anyone wants, I'll try and remember which corner of the shed I threw them into!).
I really like the VC bars. They're a good fit for me (was a big fan o the OOZY 777 as well) and definitively take the edge off. They also feel commendably stiff for such wide bars.
I'm still a fan of the SixC but don't want to go to 35mm for 800mm versions.
Posted : 20/12/2016 2:35 pm
 cozz
I tried stooge moto bars - got one of the pre production pairs
I really like them , but only problem is I have a set on 2 of my bikes, and now I've got a 3rd bike so need to buy another set !
Posted : 20/12/2016 3:49 pm
I've got a Stooge Moto bar on my bike too, also really like them. Just as comfortable as the carbon bars they replaced and make for much better handling imo...
Posted : 20/12/2016 8:21 pm
I'm interested in trying a Stooge Moto bar, but are they really suited for 150-160mm full suspension type of bikes?
I know they probably are, but does anyone use one for rock gardens, black runs etc? Just curious really.
Posted : 20/12/2016 10:25 pm
Alex - I could be keen on the Crank Bros bars depending on spec and price?
Posted : 20/12/2016 11:04 pm
