Combining Magura br...
[Closed] Combining Magura brakes and SRAM shifting on a single clamp.
I know that Magura make an adaptor themselves for this, but it seems to be designed for a very different control layout than I prefer. ย There's very little front-back adjustment so with a non-oldskool XC brake position the shift lever is more or less flat under the bar at full adjustment - not dissimilar to the Shimano iSpec which I also dislike. ย Standard SRAM MMX allows a lot more adjustment than this.
Does anyone know of an alternative mounting adaptor? ย Magura have basically mounted a lug off to the side and drilled a slightly ovalised hole through it, a world apart from the T-nut and track design of SRAM... ย I like the brakes, so I'll probably just go back to discrete mounts if I can't solve it.
Posted : 22/06/2018 9:05 pm
