Clicking sound on t...
[Closed] Clicking sound on the bike
During the last couple of rides I get quite a loud clicking sound when pedalling and I thought it sounded like it might be the bottom bracket or cranks, difficult as its been very windy.
But after todays ride it only happens when pedalling and I use the 2 smallest cogs, could it be a chain or cassette issue making the sound?
Posted : 23/08/2020 4:16 pm
I've just replaced my drivetrain because it was clicking, before it started slipping. Put it in the offending sprocket and look at how the chain sits on the teeth, it'll sit a little proud if it's about to die
Posted : 23/08/2020 4:22 pm
 RicB
My bike was doing this and it turned out to be the rear axle not done up tight. Quarter turn to nip it up and all silent
Posted : 23/08/2020 5:45 pm
Start with the easy stuff. Remove the pedals and give the threads a greasing. As mentioned rear axle, is it bolt through.? If so treat that to a bit of grease. If it's only happening in the smallest sprockets it could be the outer most bearing on the freehub body. Cranks torqued correctly.?
Posted : 23/08/2020 7:39 pm
