Click once per revo...
[Closed] Click once per revolution, only when seated but not when seated and high load
Hello all, the above is driving me mad.
The click occurs when drive side is at six o'clock and non drive side is at twelve o'clock.
If I'm standing and peadalling it doesn't happen, if I'm seated and pedalling up hill fairly hard it doesn't happen.
Any ideas?
Posted : 28/06/2019 8:25 am
Bottom bracket bearing or pedal would be my first guesses, assuming you mean crank positions
Posted : 28/06/2019 8:29 am
Had similar on my road bike, and the fact pedalling while stood up stopped it mystified me. It took me ages to find. Not saying it will be this, but grease your seat post and rails.
Posted : 28/06/2019 8:38 am
I'll go with cleaning bottom bracket threads
Posted : 28/06/2019 8:48 am
Knee.
Posted : 28/06/2019 9:20 am
 Spin
I had that too. I was convinced it was bottom bracket / crank related but it wasn't.
Posted : 28/06/2019 9:22 am
start with pedals, then eliminate each potential culprit in turn. It's usually BB/crank related but not always.
Posted : 28/06/2019 9:40 am
Ear problem?
Eliminate all variables!
Posted : 28/06/2019 9:44 am
Had simular on a road bike. Turned out the chain ring bolts needed tightening.
Posted : 28/06/2019 10:07 am
 Bez
Almost anything can be the cause of a once-per-crank-rotation click because the forces from your body go through the whole bike with the same frequency.
Cleats, pedal bearings, crank bolts, chainring bolts, bent tooth, stiff chain link, BB bearings, BB cups, seat clamp, saddle clamp, cracked frame, stem bolts, headset, you name it. (You don't mention kit: derailleur or singlespeed? dropper or standard post? 1x or front derailleur? cleats or flats? full sus, hardtail or rigid?)
Try things like riding no-handed, pedalling backwards, switching body weight between pedals without moving the cranks, turning the cranks on the workstand, grabbing the crank and checking for play, and so on.
If nothing presents itself, try the easy stuff first; then try the stuff which you can swap with items from the spares box; then try cleaning and regreasing threaded components.
Posted : 28/06/2019 10:22 am
... and so begins the descent into inevitable madness.
Posted : 28/06/2019 12:48 pm
 Bez
We've all been there. Many years ago I spent ages fiddling with stuff before realising that when I was in the granny ring my crank was just clipping the end of my front mech cable. The cracked frame took a while to discover, too.
Posted : 28/06/2019 12:55 pm
For me it was creaking seat rails that I finally diagnosed - after several weeks of rides punctuated by crazed tightening/loosening/lubing of bolts/seatposts/suspension pivots.
Posted : 28/06/2019 1:27 pm
As did I on a mountain bike once. Same cause. Actually lost one before I'd figured it out...
Posted : 28/06/2019 1:35 pm
Had it on my cdf ,turned out to be seat rail clamp was slightly loose ,not enough to feel the seat move ,a quarter turn of both bolts ,and it went
Posted : 28/06/2019 2:12 pm
One bike had a loose disc rotor bolt rubbing on caliper mount the other week.
Posted : 28/06/2019 2:14 pm
Only one way to fix this.
Load up the parts cannon and get blasting.
Change every potential culprit until you fix it or run out of money 👍
Posted : 28/06/2019 2:21 pm
Had this one winter. Bike was apart and cleaned/greased almost every week. Three months to discover it was the zip pull on my jacket on the chest strap of my bag. I nearly wept.
Posted : 28/06/2019 2:44 pm
 Rio
Had this a while ago, tightened everything visible to no effect, turned out to be the end of the internal dropper cable clicking against something which sort of echoed through the frame. A bit of tape fixed that, but I noticed yesterday it’s come back. No doubt it will be something else this time.
Posted : 28/06/2019 2:55 pm
Rear skewer (if its 5mm QR)
Posted : 28/06/2019 3:03 pm
The most obscure situation of this I've solved was a third party chainring on a 105 5600 chainset - the cause was the little metal pole that is fitted to the chainring that sits between the chainring and crank arm to help catch the chain if it falls off. This was very close to the crank arm, and would touch / click against the crank arm under certain loads.
Took *so* long to figure out, a small blob of grease stopped the noise happening.
Posted : 28/06/2019 3:45 pm
Thanks everyone, I’ve spent the afternoon carrying out what I can of the suggestions made. No noise on a quick ride up and down my street but will test further tomorrow 👍
Posted : 28/06/2019 8:36 pm
Def won't be bearings
Posted : 28/06/2019 9:43 pm
 Spin
Teach yourself not to care.
Posted : 28/06/2019 10:09 pm
Spin
Member
I think I speak for many here when I say I find that genuinely impossible.
I will systematically strip down a whole bike if necessary to find the noisy little bugger of a component!😁
Posted : 28/06/2019 11:02 pm
I had this on my cx bike (using it on the road with slicks) it was very annoying and turned out to be the rear wheel quick release
Posted : 29/06/2019 12:17 am
 10
I had this. Intermittent clicking. After going through all the usual things I found a cracked plate in my chain. It clicked when going over the chain ring. Took a while to diagnose.
Posted : 29/06/2019 4:17 am
This can always be solved by careful insertion of blue tack into your ears.
I've had most of the above cause issues in the past. Chain is a good one to check- mostly because it's a pita if it goes when out and about
Posted : 29/06/2019 7:40 am
