Chris King Bottom b...
[Closed] Chris King Bottom bracket grease gun injector users have you................
any of your flimsy seals blow through the retaining circlip? happened tonight on both sides of a bb which was off the bike got them back in but was a pain in the ass.
And what grease do you use
Posted : 04/09/2012 10:12 pm
Mine has never done that,I use Juice lubes bearing grease
Posted : 04/09/2012 10:32 pm
Thanks for the heads up, I've not tried mine yet.
Easily done. Often remove circlip and seal first then splurge the grease through. Saves having to pick it out of a load of dirty grease!
Posted : 04/09/2012 11:11 pm
So how often does one squirt it in ?
Posted : 04/09/2012 11:43 pm
2 or 3 times a year.
Posted : 05/09/2012 7:16 am
 P20
Regreased both twice, had one seal push through. It went back in ok. Using phils
Posted : 05/09/2012 8:40 am
Bit off a faff but will start to take out circlip from now on.Seems no point in having a grease gun tool!!
Posted : 05/09/2012 4:08 pm
I use mine after any [b]very[/b] wet ride.
Only had a seal pop out once and it's easy enough to get them back in.
Using Phil Woods grease.
Posted : 05/09/2012 9:05 pm
Have did you had to push you seal back in then? ๐Ÿ˜ฏ
Yes, this has happened to me also.
Posted : 05/09/2012 9:26 pm
what grease guns are you all using?
I've got a CK unit on my commuter so I'm tempted to get the injector+gun
Posted : 05/09/2012 10:15 pm
Regular cheap (dualco?) grease gun. I ordered a fitting for the CK tool so I can screw onto the grease gun rather than relying on the zerk fitting. Makes operation much easier.
Posted : 05/09/2012 10:24 pm
yeah the CK website says the injector is threaded, so the obvious thing is to thread it onto to the grease gun. The question then is - are all grease guns threaded on the end.
Was the dualco gun threaded sam? If not, where do you get the "fitting for the tool"?
Posted : 05/09/2012 10:30 pm
for future reference - the HILKA grease gun DOES fit the CK tool.
(and is much cheaper than the CK gun...)
Posted : 12/10/2012 11:09 am
 P20
That looks identical to the Phil Wood gun
Posted : 12/10/2012 11:39 am
Where's a good source for Phil Woods grease in the UK?
Posted : 12/10/2012 1:07 pm
Sideways Cycles.
Posted : 12/10/2012 1:37 pm
@sam_underhill where did you order an adaptor for the king tool to screw onto the dualco gun? many thanks!
Posted : 25/06/2013 11:29 am
ok, did a bit more poking around on line and found this:
http://www.machinemart.co.uk/shop/product/details/cgg120-4-piece-grease-gun?da=1&TC=SRC-grease+gun
which i suspect may well be the same as the phil wood grease gun and it threads into the king adapter no probs.
should fit the 3 oz phil cartridges as well..
Posted : 25/06/2013 1:48 pm
