cheapest place to b...
[Closed] cheapest place to buy the odd spoke or 2 (incl postage?)
need a straight pull 309mm spoke but may as well order a few ..anyone know where's cheapest with a good selection ?
thanks
Bill
Posted : 19/06/2017 10:09 am
J E James Cycles sell spokes singularly, but you are probably better off ringing them as the website is a rabbit hole, and the search on it sucks.
Posted : 19/06/2017 10:48 am
LBS? Mine sells normal DT comp's for 50p, dunno about straight pull though.
Posted : 19/06/2017 10:55 am
I would try a wheel-building specialist like JRA or Paul Hewitt Cycles as your problem is likely to find anyone who stocks straight-pull spokes in that size - last time I needed some, I bought them from Bike24 in Germany as most shops will only sell you a box.
Posted : 19/06/2017 11:19 am
I have a set of these.
Joggling pliers are a useful tool to have around. You can cut a longer spoke down to size. The joggled bend works just as well as the J bend on your spokes. It also has the advantage of being easier to insert into the hub, eg no need to remove a cassette or disk if you're in a hurry.
[url= http://www.greatplanes.com/accys/gpmr8025.html ]Precision Z-Bend Pliers.[/url]
You'll usually find the lbs has orphan spokes from wheel builds, so it's always best to check there first.
Otherwise my first stop is SJS Cycles.
Posted : 19/06/2017 12:06 pm
They are great - not for straight pull, though ๐Ÿ˜‰
Posted : 19/06/2017 1:26 pm
