cheapest 11-34 cass...
[Closed] cheapest 11-34 cassette with Alloy Carrier
Anyone seen any going cheap?
I don't want to wreck my pro 2 with Deore!
don't care what brand 🙂
Posted : 20/01/2012 3:40 pm
Don't forget that even XT 11-34 only have an ally carrier for the lowest 6 gears. 7,8 and 9 are steel straight into your hub. Not sure what types have an entirely ally carrier.
Posted : 20/01/2012 3:43 pm
I'm looking at SunRace but have heard good and bad about them so am still undecided
But can be cheap
Posted : 20/01/2012 3:50 pm
Assuming you're talking 9-speed? I like the SRAM PG990, and if you don't mind the 'tango orange' colour, CRC are doing them for 45 quid at the moment - buy a couple and use a ten quid off voucher to sweeten the deal...
Posted : 20/01/2012 3:54 pm
Nothing at all, XG-999/XX are the only ones that will do no damage to your freehub body, but seeing as it's basically cosmetic I really wouldn't get too het up on it.
XT or PC990 will be fine, SLX will be alright.
XG-999 at 200 and something quid equals about 5 ally freehub bodies!
As njee20 says the damage to the freehub is mainly cosmetic although a buddies SLX cassette has marked his freehub more than my XT has marked mine. Could have a lot to do with his longer legs and extra 3 stone though.
Posted : 20/01/2012 4:35 pm
Loose cassettes will do more damage too. SLX does have fewer sprockets on a carrier, 3 IIRC.
Posted : 20/01/2012 4:36 pm
Rose bikes are doing the XT at £37.90
http://www.rosebikes.co.uk/article/shimano-deore-xt-sprocket-cs-m770-spider-arm-9-speed-11-34/aid:221494
It's £5 postage but if you 'Like' them on Facebook you get a £10 off voucher code so it'll come in at £32.90.
I don't use FB but used the wifes account to get the code and it worked fine.
Posted : 20/01/2012 4:40 pm
