Hi, just doing an oil change on my 04 Drop off's which have eta. Thing is I cannot see how to measure the oil level from the stanction as the eta nut and assemeby need to be present to stop the oil pouring out the bottom of the leg.
I guess this is the way to do it - Fill level as per normal with other leg to crrect level. Pour out again and measure volume. Use this volume knowledge to gain amount for eta leg and fill eta leg upside down, through footnut hole.
Any ideas Cheers
I got a turkey basting syringe from Lakeland plastics, other kitchen shops are available, ๐ which has volume measurements on the side. Oil volume should be on the manufacturers website.
cheers. Just measured the oil on one leg ( height) then used a measuring jug for the other feeding it in from the top.
