Punctures...
[Closed] Punctures...
[#1654803]
Lately I've been getting splits at the bottom of the tubes value...is there a reason why this is happening ? Thx
Posted : 29/05/2010 3:17 pm
Valve?
Check rim tape and sharpe edges, try diffrent make tubes and be careful when you install.
Posted : 29/05/2010 3:25 pm
cheap innertubes or presta valves in shraeder drilled rims.
Posted : 29/05/2010 3:38 pm
Tyre could be moving on the rim and taking the tube with it. You could try some talc on the tube or a couple of drops of superglue on the tyre bead on one side. It used to happen a lot to my group with old skinwall tyres.
Posted : 29/05/2010 3:51 pm
Try some talc, then if the tyre moves it won't take the tube with it.
APF
Posted : 29/05/2010 5:57 pm
Cut a square inch of old inner tube, poke a hole in it and use it between the tube and the valve hole.
Posted : 29/05/2010 6:00 pm
