Chameleon riders- H...
[Closed] Chameleon riders- How many BB spacers each side?
 hora
hollow tech of course- is it 2 drive, 1 non or 3 driveside and two none?
Posted : 07/03/2009 2:03 pm
 GW
depends if you want your cranks offset or not ๐Ÿ˜›
Posted : 07/03/2009 2:25 pm
eccentric bottom bracket? Anyhow I run 2 on non drive and 1 on drive as per the shimano instructions for an xt chain set.
Check out the shimano site the answers are in the tech documents section.
Posted : 07/03/2009 4:13 pm
 hora
Pre-eccentric. Too late, I've put two in each side ๐Ÿ™„
Ta though ๐Ÿ™‚
Should help with future chain suck..
Posted : 07/03/2009 4:31 pm
Then you need to take at least one,maybe three, out.
Measure your BB shell. If it's 68mm it's 2 drive side and 1 on the other. If it's 73mm it's just 1 on the drive side.
Posted : 07/03/2009 4:43 pm
hora your a mong
your bikes must be shonks with out me or j there to help you!!
its all there in the instructions
you WILL need to take one at least out!!
shaun
Posted : 07/03/2009 4:53 pm
Its 2 on drive and 1 on none, thats how the shop set mine up on a cove stiffee with XT hollowtech 11 cranks with a 68mm shell.
Posted : 07/03/2009 5:18 pm
