Chainring bolts for...
[Closed] Chainring bolts for 30T ring and 104 BCD SLX cranks
Where's the best place to get these from please? Seeing some on Wolftooth components. I think I need a 10mm bolt, but if you know a UK supplier then that would be great!
Thanks in advance.
Posted : 02/10/2014 10:03 pm
[url= http://www.chainreactioncycles.com/chainring-bolts ]CRC[/url]?
Posted : 02/10/2014 10:12 pm
30T will just need half a normal bolt I believe (if its the screw in type)
Posted : 02/10/2014 10:13 pm
Hi Ben, you'd not happen to know the length of a normal bolt by any chance? I could maybe have a go at filing one down if I had to.
Cheers for the chaino link, the problem I have is described here:
Posted : 02/10/2014 10:17 pm
No sure, but I dont think it will matter. 8/10/12 all should work the 30T rings are threaded all the way through. I can check what RF use tomorrow if you like.
Posted : 02/10/2014 10:31 pm
Had a similar problem when I stuck a wolf tooth on SLX. Had to change the nuts to shallower ones (I think 5mm). The bolts themselves were fine. Was just what i could find in my parts bin. Didn't have the fouling problem though as it was 34t.
Posted : 02/10/2014 10:50 pm
As per Ben the bolt will go the full way through the thread on the 30t rings. I have spaced my 30t inwards 3mm for a better chain line using a dpacer and used the Raceface poly bash bolt kit which is plenty long enough.
Posted : 02/10/2014 10:58 pm
