Chain lubes, what's...
[Closed] Chain lubes, what's the holy grail all rounder de jour?
Hi all,
I'm in need of some more chain lube, and wondering what the hot ticket was for uk mixed conditions. I like a clean/dry lube but needs to last well and not wash off at the first sign of water. I've been trying out smoove as I got a little sample bottle with my rev grips, and seems very good. I've been very sparing in application too, just a couple of drops per roller and left overnight. Still smooth after a dartmoor epic, including the wet descent to Water. Runs clean too. Squirt seems a popular choice too, how do they compare? Also the new tru tension banana slip all conditions lube reads well, out performing everything according to data on their site. Expensive though. Fenwicks any good? Any input would be welcome, cheers
Posted : 06/07/2020 10:24 am
I'm a recent putoline convert after using various other magical remedies previously. Nothing comes close for longevity and cost wise it'll save a small fortune over the years.
Posted : 06/07/2020 10:29 am
I've always sworn by FinishLine Dry, but I suspect there may be better options out there now.
Posted : 06/07/2020 10:30 am
Jojoba oil going strong here.
Posted : 06/07/2020 10:35 am
I've been using Squirt all year round for a number of years now. No problems here.
Posted : 06/07/2020 10:37 am
Rock and Roll Extreme, all year.
Struggles a bit with Swinley ginge in that it needs a wipe after a run there, but I'm not sure anything is immune to the ginge.
Posted : 06/07/2020 10:40 am
Dry; Smoove (just a slightly better version of squirt)
Wet; White lightning wet ride.
In terms of chain wear and watts expended.
Then if you're the kind of person who buys an OSPW from Ceramicspeed, I can suggest making up your own waxed lube with Moly and other bits, but unless you're contesting a TT or hill climb podium, the marginal gains are not worth it. You'd probably gain less than a watt over smoove (tested).
Posted : 06/07/2020 10:41 am
I just use gt 85, as I found everything else just attracts dirt and crap.
White lightning epic on mtb and road all year
Posted : 06/07/2020 10:42 am
Another Putoline convert here
Posted : 06/07/2020 10:48 am
*sings the putoline song"
The high priest of putoline is looking for more recruits!
Posted : 06/07/2020 10:51 am
I want the best lube what do I need
ah, you've come to the right thread, you need Putoline.
Never heard of it
I'm surprised, it's a solid wax based lube that comes in a kilogram tin. It comes out top of nearly every test, cost about £30 for a tin that you'll probably be able to hand down to your children
Sounds great; wait, did you say solid?
Yep, solid, you'll need something to melt it
Ok, on the hob?
I wouldn't unless you either live alone, or have a very understanding partner. Most folk use a deep fat fryer
Ah, I see, I don't like the sound of that, I don't want waxy chips
No one does, you'll need to buy one to use solely for Putoline, you can get a cheap one from Argos
Right...this is sounding a bit more involved, anything else I should know
It stains anything it comes into contact with, and you'll have to take the chain off the bike, but at least you won't have to do it that often, it lasts for ages.
Right, well my grand-dad had gardening trousers, so I think it'll be cool to have some chain lubing versions.
That's the spirit
Anything else? it does all sound a bit like a ritual each time I want to lube my chain.
Well it does have a bit of cult following, and you'll have to admit that TJ was right all along...
Bugger, what in public?
Yep, although if you can't bring yourself to do that, if you ask him nicely, he might do a chain for you for free, so you can test it before you buy everything.
That sounds cool.
Yep, TJ is one of the good guys, don't say anything though, as I'll never live it down
Mum's the word.
Posted : 06/07/2020 10:54 am
Putoline +1
Struggles a bit with Swinley ginge in that it needs a wipe after a run there, but I’m not sure anything is immune to the ginge.
Putoline survives until the conditions are absolutely biblical. It survives rain or mud, but not 30 miles in the sort of weather that turned the NE Switchbaks into a stream (Gorrick 100 circa 2010)!
Posted : 06/07/2020 10:55 am
Greetings, lube-brother - exactly the same here!
Smoove is excellent, but the downside is a build-up of wax around the jockey wheels after a few reapplications. Not really an issue as every few weeks, it all comes off for a proper degrease anyway, but it's the only real downside I've found of it.
LOLz@ nickc!
Posted : 06/07/2020 11:05 am
I’ve said this before, but putoline is so good, that nothing else really compares.
It’s in a different league to anything that can be poured onto a chain.
It doesn’t attract dirt, it resists biblical conditions better than any little bottles of ‘lube’.
£30 for that, £16 for a cookworks dff at argos, and some quicklinks for the chain and you’re pretty much set for life.
Take chain off bike, heat wax up to c140 degrees, dunk chain in there for 15 mins, lift basket up to let it drip dry for 5-10 mins, then wipe chain off with your wife’s favourite curtains.
Or, if you don’t want a divorce, use an old rag.
Your chain will now be smooth and clean for a few hundred miles of perfect running.
Posted : 06/07/2020 11:08 am
Juice Lubes Viking Juice all year round, not had an issue.
Posted : 06/07/2020 11:30 am
ive been alternating between smoove and squirt (on different chains) to test the difference,
smoove is better. ill be moving back to that once my squirt runs out.
Posted : 06/07/2020 11:52 am
White Lightning Epic Ride is my chosen one lube to rule them all.
Though I do use cheaper wet lube or dry lube from my stock when it's particularly minging or dry.
Haven't tried Smoove though, looks very promising.
Posted : 06/07/2020 12:11 pm
<snip>
Any thoughts for road bike use? Downside would be mileage - few hundred miles isn't so much on a road bike and I'm not sure that I could be arsed going through this every couple of weeks, when I can just spend 30s applying some more Smoove every few days instead.
Interested in people's experience here.
Posted : 06/07/2020 12:39 pm
I’ve been using Squirt recently. It’s ok, but it leaves my chain and cassette looking a bit grubby - maybe I’m using a bit too much? It lasts for a 100km or so I’d say, thing like the distance they claim.
When I finish the bottle I’m going to try Smoove as it has some fans around here.
If I’m not impressed with Smoove I’ll go back to http://www.boeshield.co.uk/category/boeshield-t9-bicycle-mountainbike/ , I reckon that’s the best thing I’ve used.
Posted : 06/07/2020 12:41 pm
Dearn - I used it on my commutter doing 35 miles a week and did it twice a year so maybe over 1000 miles in summer and over 500 in winter. I also used it on the tandem 400 mile road / offroad tour with some rain and it didnt need redoing on return indeed didn't get redone for months
I think I get a couple of hundred miles winter MTB, 400+ summer MTB, 500+ miles winter road, 1000+++++ miles summer road out of one application - only roughly tho as I do not note it down and its so rare i redo them
Chain life I think is about 4 times as long
edited as I cannot do basic arithmetic
Posted : 06/07/2020 12:47 pm
I used my own very special mix of chainsaw oil and white spirit.
But people think I'm odd.
Posted : 06/07/2020 1:01 pm
I’ve used putoline for a year or so now and it is good, one of the few chain lubes that can survive a wet sandy Surrey hills, but there are a couple of downsides.
It covers your drivetrain in sticky black wax, never an issue for me with my SRAM eagle black cassette, but if you’ve a shiny gold, silver etc cassette and chain then it might not be for you.
Also if you get it on your clothes then it doesn’t come out. I’ve a couple of pairs of gloves that have black stains on the fingers where the chain has dropped and I’ve had to handle the chain to get it back on.
I’m happy to live with those issues for the benefits but others might not.
Posted : 06/07/2020 1:16 pm
putoline when i remember and then the first thing i can grab in the shed to stop the chain sounding crunchy after not bothering to clean it after riding on the wet beach.
Posted : 06/07/2020 1:32 pm
I use both Smoove and Peatys now, which seem to cover all bases, plus Pedros Ice Wax on the good road bike.
Need to decide what to put on my new ebike - it’s had a handful of rides so far on the factory lube so will be due either a top up or a degrease and start afresh soon.
Posted : 06/07/2020 1:34 pm
Dearn – I used it on my commutter doing 35 miles a week and did it twice a year so maybe over 1000 miles in summer and over 500 in winter. I also used it on the tandem 400 mile road / offroad tour with some rain and it didnt need redoing on return indeed didn’t get redone for months
I think I get a couple of hundred miles winter MTB, 400+ summer MTB, 500+ miles winter road, 1000+++++ miles summer road out of one application – only roughly tho as I do not note it down and its so rare i redo them
Thx. It probably makes sense for a commuter bike which often don't get much love. Not sure I'd want to ride around with a filthy-looking drivetrain on the summer bike though - it would offend me far too much 🙂
This would, I presume, be compared to someone who neglects their drivetrain - i.e. Putoline once per 6 months vs slapping some 3-in-1 on at the same interval. I could definitely believe this, but for those of us that maintain their drivetrains properly, I am sceptical in the extreme of such claims!
Posted : 06/07/2020 2:12 pm
Its not a filthy drivetrain and thats compared to me using finish line wet and maintaining the bike properly ie regular degrease of the chain and a relube with finish line. to me it really is that much better
My commutter gets a lot of love! I cannot stand noisy and neglected bikes.
~this is the drivtrain of my fatbike after 2 3hr wet rides after putolining it. so after 6 hrs usuage in wet a muddy conditions - the chain is still perfectly lubed at that point
[url= https://live.staticflickr.com/65535/49338785312_4b16c2acae_c.jp g" target="_blank">https://live.staticflickr.com/65535/49338785312_4b16c2acae_c.jp g"/> [/img][/url][url= https://flic.kr/p/2iaUaWh ]IMG_1265[/url] by [url= https://www.flickr.com/photos/25846484@N04/ ]TandemJeremy[/url], on Flickr
Posted : 06/07/2020 2:16 pm
Dunno where you are Daern but get a chain to me I will treat it and get it back to you so you can try it. Post if you want
I'm edinburgh based
also in that pic above the cassettee has not been cleaned since I got the bike! maybe a thousand miles? its never been lubed with anything else thats just how it always looks. a bit of dry hard wax covered in dust
Posted : 06/07/2020 2:27 pm
Finish Line Wet is pretty much the poster child for attracting drivetrain filth, though.
Posted : 06/07/2020 2:31 pm
Absolutely, it's like a mankmagnet, Smells great mind!
Posted : 06/07/2020 2:41 pm
Any thoughts for road bike use? Downside would be mileage – few hundred miles isn’t so much on a road bike
A few hundred miles of sodden gritty off road. On road or in dry conditions it lasts probably a few thousand. I did my rigid bike and my road bike just before lockdown, still smooth and I rode loads.
If you get it nice and hot and really rub it down well then it doesn't get your cassette grimy. I didn't do this well enough on my road bike at first and it got grimy, however it's only the excess that came off. Once I'd cleaned the cassette once it stayed pretty clean. Perhaps not suitable if you want a showroom finish every ride maybe.
Being solid it also doesn't get on the outside of your front mech so you don't get an oily leg.
Also worth noting that as well as staying on for much longer it's also much quieter than fresh drip-on lube ever is.
Posted : 06/07/2020 2:45 pm
Forget Smoove or Putoline wax (Putline also has other chainlubes mind you); Smoove gunks up your jockey wheels ans chain terribly, re putoline wax - read the above, plus it's a lot of faff to apply, one of the most expensive options if you factor in the time cost, only for people enjoy diddling around with their bikes.
What you want having tested a dozen lubes is Weldite TF2 Performance.
d
A very low viscosity all-weather lube with teflon, absolutely minimal gunking up of the chain or jockey wheels, needs to be reapplied more often than waxes and thicker lubes but this takes 10 seconds, extremely easy to clean off too and cheap as chips.
Posted : 06/07/2020 3:54 pm
Wish it was this simple, there's no way anything of that sort is going to withstand a long day of wet splashy trails and roads. My painstakingly applied Fenwick's stealth, which otherwise seems quite good, was a dry squeaky mess after 80km of Fife's best 'gravel' (read: puddles, connected with mud) at the weekend. I'm fine with frequent applications of lube, but not trailside.
I'll come round to Putoline one of these days, it's the initial outlay and learning curve that puts me off, plus I'm ashamed to admit I like the chain on my 'good' bikes to look nice and bright and silver...
Posted : 06/07/2020 4:39 pm
Wish it was this simple, there’s no way anything of that sort is going to withstand a long day of wet splashy trails and roads.
It is that simple, it's long lasting for a low viscosity lube and the best of both worlds - no need to faff around with wax possibly with the exception of those squeezing out every last marginal watt gain - another UK forum review:
I've been Weldtite TF2 Performance since early Autumn last year and found it to be very good,especially in wet weather drivetrain remains quiet and rollers don't shine up for ages,a sure sign the lube is still working internally where it's needed most.Time/mileage between relubing is loonnnggg and it doesn't attract road and trail dust and dirt much between chain cleaning.
Posted : 06/07/2020 4:46 pm
, re putoline wax – read the above, plus it’s a lot of faff to apply, one of the most expensive options if you factor in the time cost, only for people enjoy diddling around with their bikes.
Even if I figure my time at £20 an hour its still miles cheaper than anything else because the wax s so cheap and you do it so infrequently - and you save on drivetrain wear
Its interesting that since I started banging on about this loads of folk have tried it and only 2 have given up on it
It really is to me a quantum change its so good
Posted : 06/07/2020 4:48 pm
I’m ashamed to admit I like the chain on my ‘good’ bikes to look nice and bright and silver…
Nothing to be ashamed of, I don't want a black chain (and clothes) either - and I don't want to faff with a deep fat fryer every month or so.
Also, I just don't feel right if I haven't lubed up pre-ride.
I might spend £15 a year on lube (maybe less), but it's one bit of biking that doesn't really need fixing for me.
Posted : 06/07/2020 4:51 pm
I don’t want a black chain (and clothes) either – and I don’t want to faff with a deep fat fryer every month or so.
Putoliner here - no black chain (if you wipe the excess off well, like any lube), no black clothes (ditto), some faff but more like every six months or so.
Posted : 06/07/2020 4:55 pm
It is that simple, it’s long lasting for a low viscosity lube and the best of both worlds
actually d'oh, hadn't realised it was a wet lube, assumed teflon = dry lube...
So a wet lube that doesn't pick up muck etc, could be worth a look.
I'm using Morgan Syn Lube blue on the winter bike and CX bike, it runs beautifully but seems very sensitive to how much you apply and seems to leach out of the rollers over time, you think you've applied sparingly and wiped off excess then next morning your chain appears to be swimming in it again!
Posted : 06/07/2020 5:04 pm
13th - I'll do a chain for you as well if you want to try it. I know you are fairly local
Posted : 06/07/2020 5:06 pm
ven if I figure my time at £20 an hour its still miles cheaper than anything else because the wax s so cheap and you do it so infrequently – and you save on drivetrain wear
Don't think so. And I doubt chain wear with teflon lube reapplied weekly is that much worse than wax? Or do you get 3 times longer chain life out of wax? Which is the only thing I could think of that could warrant the faff.
Putoline time to remove and reapply: 30 min, frequency of application once every 3 months.
Time cost/year: 2 hours or £40 @ £20 pr hour.
Putoline cost £25/kg - not sure how much you use pr year, but let's say 50g, so £1-2 pr year, total cost £41-42 + one time wax heating device cost, let's add £5 for that so £44-47, more if you value your time more..
Weldtite TF2 Performance time to apply: 15 seconds, frequency of application every week (aggressive).
Time cost/year 13 minutes or £4.3
Weldite TF2 P cost £30/kg, 100 ml lasts me a year, so cost is £3 pr year, total cost pr year = £7.3.
Weldtite TF2 Performance is 6 times cheaper than putoline factoring in all the faff..
Posted : 06/07/2020 5:08 pm
 mboy
I'm staggered just how many people are getting on the chain waxing bandwagon! REALLY?!?! I mean, if you're a Pro roadie (well you'd have a mechanic to do it for you then) and the last 0.1% matters then ok, but for the rest of us...?
Juice Lubes Viking Juice is the single best lube I've used, bar none... Use it all year round on the MTB, and about 11 months of the year on road (when it's hot and dry enough, their ceramic lube comes out on the road bike, but it can get dirty quickly in sub optimal conditions)... Superb stuff!
Posted : 06/07/2020 5:10 pm
Can't remember if I've posted this before buuuut GEEK OUT! dit diddly da, dit diddly da, GEEK OUT! (apologies to Nile Rogers) https://cyclingtips.com/2018/03/fast-chain-lube-that-saves-you-money/ or everything you wanted to know about chains and chain lubes but were afraid to ask. Be warned there's a whole series of articles down that particular rabbit hole!
I'm currently using Muc-off wet lube but that's partly because I need something I can apply whilst out in the sticks on multi-day rides and not all lubes play well with the various chain coatings or putoline.
Forget dry lubes off-road, one dousing of that milky tea coloured grit filled water and in ten km your chain will be squeekier than a leather fetishist's convention!
Posted : 06/07/2020 5:11 pm
Drivetrain wear with teflon lube reapplied weekly shouldn’t be bad at all.
The problem with all drip on lubes is that they wash off in no time at all in wet mud. And they get gritty very quickly even if they are also still oily. Putoline doesn't get gritty.
I mean, if you’re a Pro roadie (well you’d have a mechanic to do it for you then) and the last 0.1% matters then ok, but for the rest of us…?
It's nothing at all to do with performance. For me it's about not destroying chains with grit, and about ease of use. Yes, really. The chain doesn't get gritty, which means it doesn't need a thorough clean and the chain doesn't get ground to death.
It's not just 15 seconds to apply, it's 5 mins getting all the crud out of your chain if you are quick and efficient, or cleaning off accumulated gunge if you just reapply all the time.
I spent 25 years trying everything looking for the most durable lube to protect my drivetrain and the easiest maintenance routine. Putoline is both.
Posted : 06/07/2020 5:26 pm
Putoline is even better for multi day trips, because you don't need to do anything or bring anything.
Posted : 06/07/2020 5:28 pm
@molgrips - would you set off on something like the HT550 with a putoline treated chain? Not being confrontational here, just curious if you'd consider it given that even in a dry year there are some full on dunkings with the river crossings.
Posted : 06/07/2020 5:34 pm
t’s not just 15 seconds to apply, it’s 5 mins getting all the crud out of your chain if you are quick and efficient, or cleaning off accumulated gunge if you just reapply all the time.
So you're saying you don't need to clean the chain at all for 3 months with putoline??
My application is for road so there's not that much crud, clean the chain every 2-4 weeks.
Posted : 06/07/2020 5:38 pm
nope - less than 5 mins of stuff yo have to do - most of the time is waiting time you can do something else in.
Chain off bike - 30 seconds. find tin put on stove and turn stove on 10 seconds. Put chain in tin 2 seconds. Take chain out of tin and hang up to cool - 5 seconds refit chain to bike 30 seconds wipe down chain a minute maybe if I have to look for a rag
and yes - its a huge improvement in chain longevity. I have gone from 4 chains a year with associated drivetrain replacments to a chain every year or so
Posted : 06/07/2020 5:39 pm
This would, I presume, be compared to someone who neglects their drivetrain – i.e. Putoline once per 6 months vs slapping some 3-in-1 on at the same interval. I could definitely believe this, but for those of us that maintain their drivetrains properly, I am sceptical in the extreme of such claims!
It's more that however well you maintain your bike in the shed, if you go out in the wet then the lube will wash off in perhaps 20 miles (depending on how wet and muddy it is), nothing lasts forever.
This means if you go out for a long ride then all those miles after ~20 are on a dry chain, which is what is wearing it out. Every time you go out and ride for slightly longer than the chain lube can survive you're wearing the drive chain. With solid wax-based lubes that almost never happens, as a result the drive chain is almost never wearing out.
If you have to lube your chain before a ride, then that means that the end of the previous ride was sub-optimal.
As for cleanliness, you can mostly mitigate that by wiping the chain thoroughly after waxing. On my road bike the cassette turns a dull grey as there's a deposited layer of graphite and wax doing it's job by lubricating and protecting it. If it bothers you then a rag with some white spirit wipes it off fairly painlessly, but then you've probably introduced some metal on metal friction. And dirt doesn't stick, once the cassettes turned grey that's it, it doesn't change or need cleaning ever, I just hose my bike down after a muddy ride and put it away, no bearing eating degreasers or jet washing needed.
Putoline is even better for multi day trips, because you don’t need to do anything or bring anything.
+1
And it plays just fine* with wet lubes. I take a little dropper bottle of chainsaw oil for emergencies on multi-day tours/trips but have never actually used it.
*if you consider the standard wet lube gunky black mess to be fine.
You omitted cleaning your drivechain in that calculation.
And the cost of replacing chains and cassettes. If a chain is £20 then by the time it's extended it's life by double (or treble, or quadruple) then that £25 tin has pretty much already paid for itself.
As an anecdote my road bikes on it's second "winter" cassette and original "summer" one. That means it's worn approximately 2 cassettes since 2008. I'd work that out in miles but it predates Strava.
Pre-putoline I worked on the assumption a cassette lasted about one winter, or two summers.
Posted : 06/07/2020 5:41 pm
Whitestone - yes. It does not wash off in water. I have done two 400 mile tours on the tandem mixed road and off road and the chain still has plenty of lube left in it. Marginal tho depending on weather.
Two things seem to strip it out of the chain - acid soils like peat and science officer had some issues with a particular soil type.
Yohandsome - yes - you never need to clean the chain again
Posted : 06/07/2020 5:42 pm
Yohandsome – yes – you never need to clean the chain again
Ok so are these claims true dear putoline apostles:
1. 2-4x longer chain life
2. 2-4x longer cassette life
3. No chain cleaning whatsoever (no gunk buildup on rollers even?)
4. Reapplication every 3-6 months, takes 30 min
5. Marginally faster than wet lube
6. Turns the chain black-ish due to graphite content (pro or con depending on your aesthetic preference..)
Why get a fryer though
d
Posted : 06/07/2020 5:56 pm
take 10 mins not 30 apart from that yes
Look at the pic I put up of my bike. thats done around 1000 miles in that pic and been treated twice and never cleaned. Its still well lubed, no gunk build up. It won't need redoing for another couple of hundred miles at least
I actually think its probably a tiny bit slower than a well lubed and cleaned chain using oil - but its loads quicker than a chain thats lost all its lube at the end of your ride
Posted : 06/07/2020 6:09 pm
I use fs365. Its from scotoiler. Used on motorbikes. I have immaculate drivetrains. Need to apply every ride bit only takes about 20 seconds. Stores in a bottle in the cupboard. Water based so easy to clean off floor and clothing. I ran a chain for 2 years and it didnt get to 50% and i live in scotland so mud is a year round reality.
Why the hell would i want to faff about with a deep fat fryer! You guys be crazy!
Posted : 06/07/2020 6:11 pm
It's not really a faff. Cleaning chains is far more faff. And with Putoline the chain is really clean, it passed the twist test.
I think some people aren't that bothered about a grit-free chain. I am picky about it though.
Posted : 06/07/2020 7:01 pm
yohandsome
The fryer is so you can do it in the shed and not get a bollocking off the OH for stinking out the house. It's also safer than having a wobbly tin on a stove somewhere.
All the above would appear to be true, although I am a recent convert so can't personaly vouch for the longevity claims.
6 isn't neccesarily true depending if you wipe the chain after treatment.
First chain I did I let drip dry and it had a sticky brown coating which came off on hands, clothes, cassette etc. Second chain got a good wipe straight after coming out of dff and it looks a dull silver with a slight waxy feel on the side plates like the surface of a wax crayon.
Mostly riden in the dry so far but after one very shitty ride it got a good high pressure hose wash down and muck just fell of leaving chain just as it was after the wax treatment.
MODS! Isn't it time there was a sticky(no pun intended) for this.
Posted : 06/07/2020 7:09 pm
Shit! Having transferred Yohandsome's model to other aspects of my life I've just realised I spend more than 30 days per year washing my dishes. I'd better get rid of the dishwasher, with its 2 hour cycle that's 730 hours a year!
I'll spend the time saved polishing my drivetrain.
Posted : 06/07/2020 7:19 pm
You can spray WD40 on a rag and wipe it down at any point, not just when you've fried it up. This can help keep things clean if you find bits of wax have worked their way out.
Posted : 06/07/2020 7:43 pm
@molgrips I rather like the thin waxy coating on the plates preventing corrosion. Would the WD40 take that off?
Posted : 06/07/2020 7:47 pm
It’ll be a lot longer on road, my ‘road bike’ gets used as a semi mtb too and I usually get several months out of one application.
Putoline isn’t comparable to anything you drip or pour onto a chain because it gets right inside the rollers, precisely where you want it.
Posted : 06/07/2020 7:50 pm
I must admit, I have Putoline in my ebay watch list, but I'll [i]never[/i] actually buy it.
What works for me, is cleaning and spraying with WD40 after seriously shitty rides. Then, if it's wet, dribbling whatever dry lube that is nearest on to it (just a tiny amount). Currently either the cheap, white stuff Halfords sell (Pure) (it smells nice), or Muc Off dry lube (had it years). If it's dry, the wd40 does the job.
Anything else is just a bloody unnecessary faff.
Posted : 06/07/2020 8:12 pm
Is it though? I always hated cleaning the chain and drivetrain on the bike after a ride, found it to be a messy unpleasant business with ususally not very good results. I used to be a WD40 user and always found that despite best efforts, every so often I would have to strip things down to give it a good clean.
Putoline is a doddle in comparison in my view.
Posted : 06/07/2020 8:40 pm
Fenwicks stealth. Keeps the drive train smooth and attracts no dirt in the dry or wet.
Posted : 06/07/2020 9:20 pm
Juice Lubes Viking Juice 😀
If your not waxing
Posted : 06/07/2020 9:36 pm
Looking on the official Putoline website,on the instructions it says to just heat up in the tin? So no need for a deep fat fryer? Could do it in the garden with a camping stove to eliminate smell etc? Does it leave a gum around the cassette/chainrings? I'd rather keep them as mank free as possible.
Posted : 07/07/2020 6:35 am
Fryer in garage means you can switch on - forget about it for 30mins - remember and plonk in chain - which you then also forget about - then remember and remove throw on an old towel to wipe and leave - then remember to find the now cold chain and install.
Compared to forget about the stove and dial 999.
Posted : 07/07/2020 7:00 am
Putoline in garage on a big flat camp stove, the canister ones. Much quicker than cleaning rinsing and drying chain.
Especially if you like a potter/ beer/ tunes in garage. Mine has never been tidier.
Posted : 07/07/2020 7:38 am
I put mine on the kitchen hob. Fortunatly when I installed the kitchen I put in a massively powerful extractor 🙂
As above - the DFF is perhaps safer from a fire point of view and certainly safer from the wife point of view 🙂
Posted : 07/07/2020 9:00 am
I've not cleaned a chain or cassette since the days of wet lube, the only cleaning is the odd scraping of built up mud from jockey wheels with a wee screwdriver.
The putoliners seem to think the rest of us spend hours cleaning stuff, to justify their own bizarre rituals. 🤣
Posted : 07/07/2020 9:15 am
I like a bizarre ritual or two 😉
Posted : 07/07/2020 9:30 am
No beer - religious rituals always look bizarre to outsiders.
Posted : 07/07/2020 9:39 am
this stuff? Many ££££s
Posted : 07/07/2020 9:43 am
So did I, back in the 90s when I used to religiously cover my chain in the sticky shite that dirt clings to and make it more difficult to clean.
Ah, remember the black clag that Finish Line used to leave over the chain and cassette.. never have to clean like that any more.
Posted : 07/07/2020 9:51 am
On the time calculation your not adding in the cleaning of all that hard black shite from the jockey wheels, cassette, front chain rings and occasional proper chain clean down. You don't get that build up with wax.
Posted : 07/07/2020 10:22 am
The only chain lube I’ve used that’s anywhere near putoline in terms of surviving wet gritty rides in Surrey or Wales in Rex domestique. It’s easier to apply and cleaner but doesn’t last as long as putoline. It can go a good few shitty rides before reapplying though. It’s more expensive in the long run, but if you prefer a clean looking chain and cassette it’s certainly the best I’ve used.
Posted : 07/07/2020 11:03 am
^^^^ £13 for a 30ml bottle, eek, that is pricey.
Reading the blurb it looks very similar to Smoove...
Posted : 07/07/2020 11:24 am
It does last a long while though as you use it infrequently and you just put a tiny drop on each link.
Posted : 07/07/2020 11:41 am
Pultoliners used to do it the old way, now we've tried something else and found it better. Some of us are capable of critical evaluation!
It is nice, a bit high maintenance for mixed riding though, I think I'm only getting between 100km and 150km per application.
Will finish my two bottles, and in the meantime maybe take the plunge with Putoline on the winter bikes, it can only be cleaner than the current black sticky mess. All going well I'll maybe commit on the gravel bike as well, just a shame it's also my CX race bike, there's something about Putoline which doesn't scream 'race' to me, couldn't they do an extra special 'race' blend and charge me extra for the privilege? 😉
Posted : 07/07/2020 11:52 am
13th - serious offer to do a chain for you
Posted : 07/07/2020 11:54 am
Christ, you'd think one of the cult messiahs would spell it properly, tj will have you on the naughty step. 🙂
Tbh, you lot always compare it to the shittiest old stuff, such as finish line wet, as Dez says we stopped using that years ago. As Chaka says, it's about 15 quid a year lube (I use for RnR), I never have to clean my chain, takes 30 seconds to apply, and lasts more than long enough for my needs, it's a problem that just doesn't exist.
Posted : 07/07/2020 11:58 am
