Chain falling off.....
[Closed] Chain falling off...
4 Users
Been tweaking my young-uns bike.
With a single ring up front (removed the middle and inner rings from the original 3ring crank, leaving the outer) and a 7speed block out back, the chainline means is pretty kinked in gears1-3. Ok when pedalling but when he pedals backwards the chain drops off the front ring.
What's the best cheap solution? Chainguides seem pretty pricey but I guess would work. Can I somehow change the front ring line distance?
Posted : 17/04/2010 7:57 pm
if its a square taper bottom bracket then a longer one will move the chainset over and improve the chainline.
Posted : 17/04/2010 8:15 pm
Cheap solution = tell him to stop pedaling backwards!! 😉
Posted : 17/04/2010 8:18 pm
Dibbs - already done that! Doesn't work.
Toppers - chainset needs to move inwards.
Posted : 17/04/2010 8:38 pm
I have a N-Gear jump stop chain thingy combined with a bashguard on my 1-9 setup. Haven't dropped my chain since installed.
http://www.jdcycles.co.uk/components/chains/n-gear-jump-stop-chain-guide
Posted : 17/04/2010 9:28 pm
