Centrelock rotors- ...
[Closed] Centrelock rotors- talk to me like I'm some sort of know-nothing bozo.
Got some nice DT Big Ride hubs but they're centrelock, I've not had centrelock for ages... Had a look and I can just sling a set of XT or XTRs on it but that left a couple of questions, maybe someone'll know
Do these rotors work OK with Formula The One brakes? The rotor track looks a little wider but also they have the alu carrier which I gather interferes with some brakes. It'd be 180 and 160.
They're not that light are they? Maybe I'm wrong but it seems like adaptors (maybe the Ashima ones) and typical steel 6-bolt rotors work out lighter. As well as cheaper and easier as I have lots of 6-bolts. Am I missing something? I'm not an outright weight weenie (these are for a fatbike!) but I'd rather not spend more for heavier.
Anything else I need to think about?
Posted : 05/04/2016 10:50 am
 hoke
You clearly know too much already to be overthinking it quite this much.
I suggest riding one of your bikes instead.
Posted : 05/04/2016 10:56 am
Well I would but it doesn't have any brakes ๐Ÿ˜†
Posted : 05/04/2016 11:15 am
 hoke
Never understood why beach bikes needed 'em
Posted : 05/04/2016 11:19 am
I have centrelock rotors on the Amazon with BB7s. The little tab on the pads that's used to help pad removal and installation fouls the spider by a few mm so I just shorten them before fitting.
In theory, a centrelock hub can be a bit lighter so the total weight of rotor and hub, or rotor adapter and hub probably works out very close.
Posted : 05/04/2016 11:23 am
 hoke
You can just bend that tab out the way on Avid pads
Posted : 05/04/2016 11:35 am
Erm the RT-81 carrier is a fair way inboard of the braking surface
180 mm
160 mm
No help to you but with 396s the contact area is exclusively on the outer vented part of the rotor a long way from the labels and direction indicator
Seem to recall the 160 was 120 g. 50 g lighter than the manhole cover-like RT20 it replaced
Posted : 05/04/2016 12:05 pm
