Would it be possible for people to share their base tunes on here for the MEGA AM with CCDB coil
Rab
There is no base tune for the mega on the cane creek site
There is most definitely base tunes for all nukeproofs in the link i put up.
EDIT: Not so sure
From the cane creek website: "Factory Neutral: We do not currently have a Base Tune developed for this bike."
My set-up:
25% sag
HSC: 2.5
LSC: 17
HSR: 1
LSR: 17
Took off the high speed rebound to make it pop more off jumps and lips, and put on a little extra high speed compression to keep it controlled on big landings, and propped up a bit more in corners.
Added a few extra clicks on both low speed rebound and compression just to make it climb a little better and not move around so much when out of the saddle pedalling.
The only downside is that on bigger landings (to flat) it can buck a little bit. My goals were to get it a little more playful, without compromising it over chattery small bumps, and it seems to have worked pretty well.
