I have the above shock and im trying to reference some base settings for it.
Im struggling with the 'clicks'. It has 4 separate adjusters for HLC, LSC, HSR and LSR.
Now i believe the LS circuits use a needle valve and these ones have a definate click when i adjust them.
I also believe HS circuits are a shim stack, and when i adjust these two adjusters i cant feel or hear a click. Am i doing something wrong? Or am i fat fingered halfwit?
Beener
No clicks on the high speed circuits and both use poppet valves.
im sure my manual says clicks...do i just tune by feel then?
Careful.. on mine the high speed circuits don’t click when adjusting the low speed ones do.
it says in my instructions that you need to be carful adjusting the H/S circuits as they don’t have a hard stop and are fairly easy to over adjust, which is a trip to the menders apparently..!
ok...i will definately keep that in mind! thanks
The HSC and HSR aren't clicks, they're turns. So 2 = two full turns.
The LSC and LSR are clicks, so 2 = 2 clicks.
Don't userdo it, when the turning stops - stop. There's a circlip on each adjuster, and if you're hamfisted you can snap it.
ace! thank you for that!
