Just looking around for a carbon riser with more sweep than the last years PX Selcof.
I was doing a comparison against the the Brand X 38mm riser when I noticed PX are claiming 50mm rise for the current bar. Even just holding a rule vertical and using line of sight I would have to disagree with that on the Selcof bars I have.
Are the current PX Selcofs different to the previous one or the same. I estimate mine to be 25mm not 50mm.
Any other recommendations for a carbon riser with at least 10 degrees of sweep?
First choice would be the Chromag Cutlass but a bit spendy.
https://www.sq-lab.com/en/products/handlebars/sqlab-handlebar-3ox-carbon-12.html
highest riser is 45mm
Not cheap though!
Syntace vector carbon is similar
+1 Syntace Vector (12deg)
