Can`t Jump - Dare`n...
[Closed] Can`t Jump - Dare`nt Jump
66 Users
The rewards of jumping don't balance the price as you get older.
That statement makes me sad. I don't ride a bike because, on balance, it seems like a good idea at my age. I want to do 20ft doubles when I'm 50, which means I only have 17 years to learn!
Posted : 15/02/2010 11:43 am
I have yet to see any convincing reason that says jumping off the ground, twisting in the air and shouting culman is an essential part of riding a bike. It maybe something you like to do but I cannot see that it is essential. Why make life difficult? And I haven't said that I'm refusing to try, I just don't see the need to learn something that I'll hardly ever use. Most of the jumps I see carried out are over puddles or small obstacles on straight flat bits of track. What a waste of time and effort. The "big air" pics on here all seem to be on specialist tracks that are set up just for jumping and showing off. Don't go to those places, so don't need to do it.
yeti are you on an FS bike? if so its potentially a damping issue, if not its surely weight distribution or yanking up too much on ya feet (probably only likely if you're running spd's) are you?
Posted : 15/02/2010 11:44 am
Can jump, can't land.
One thing that's giving me trouble at the mo is a jump on a trail that i've done a million times, but is presently a bit worn down as you hit the lip, so there's a nice smooth upslope, but then a couple of inches of treestump sticking out upright at the top.
Now on a regular trail I KNOW my back wheel would just roll over that, legs and tyre would soak it up and i'd carry on in the intended direction, but on a hardtail at least my brain has convinced me that my front wheel will go over, the back will hook up, I will rotate round the rear axle and plant my face in the trail. I just can't get it, I'm going to have to go up there with a spade and sort it out.
Posted : 15/02/2010 11:49 am
For me jumping and bunny hopping just adds to the riders toolkit.
Hipping bus stops or lifting your front wheel to manual and then spotting a line to bunny hop a root section.
The fun is being smooth and silent as possible - hanging up back wheels and flat landing is horrible - if you can't jump it doesn't help with that.
Posted : 15/02/2010 11:53 am
Sounds like you need to use the stump as a kicker to get the bike pointing upwards. The rear wheel should then just barely touch it.
Posted : 15/02/2010 11:54 am
10pix went to Holmbury and Pitch instead so no. Will do though!!
Posted : 15/02/2010 11:57 am
Eccles, I don't know about jumping, but I can testify to the fact that you can land, albeit in an elephant into an orchestra pit stylee. Give us a shout if you're up for a mid-week skyve ride some time, it's been ages.
Posted : 15/02/2010 11:59 am
I have the same ability to get plenty of air but never stick the landing. Usually ending up nose or rear heavy, but occasionally combine that with sideways and at an angle. At speed this manifests itself with plenty of squeeling and torn skin, at low speed I just fall off and wish I@d never bothered.
Still, I want to. I need to.
Posted : 15/02/2010 12:08 pm
get to a bmx track, learn properly. out on an xc ride or at a trail centre there are so many additonal variables (badly shaped jumps, worn out lips, mud, ice etc.) so you'll never really learn what you are doing wrong.
get to your local bmx track, learn how to pump properly and consistently, then get flying.
Posted : 15/02/2010 12:13 pm
I’d say confidence is the key skill, you probably have 90% of the muscle memory, bike control skills you need to get comfortably aloft and safely back down, more often than not it’s simply head games, the major trouble with riding a trail where there is a jump ahead, is that you know it’s coming, you’ve eyed it up, run through all the potential ways you can injure yourself, and the whole of your run in is spent mulling over your certain death… What you haven’t done is think, yeah I can have that and just ridden it.
It pays not to be too much of a thinker sometimes, certainly on first attempts, it’s the same principle as spotting the right line through a corner, you know what to do, it’s simply a case of doing it and turning down your instinct to avoid risk (easier said than done sometimes I know) but over analysis doesn’t really help, you don’t have to thow down instant 50ft gaps, and all the whips, X-ups and tricks are really just decoration, the odd clean 2-3ft double is not beyond you… Honest…
Being able to precisely pick and place landings and take offs for clearing obstacles like roots, stumps and rocks means you will be able to carry more speed and save energy, and once you’ve learned to read jumps then it’s a skill that can be applied to any trail you ride…
Posted : 15/02/2010 12:15 pm
Tried a jump once, landed on my head and bent my finger to the side damaging the joint. Took a few months to get better. My joint is still bigger than the others. I blame it on foot and mouth, all the proper trails were shut. Try to avoid leaving the ground at all costs now.
Posted : 15/02/2010 12:18 pm
The funny thing about jumping is that you imagine it must be tricky, but actually it is deceptively simple. Usually people are coming to grief because they are putting too much fuss into it, making it too complicated. Of course the trick is to makes sure that you are doing the correct simple thing, rather than the wrong simple thing!
Posted : 15/02/2010 12:44 pm
 jedi
in all the eyars i have been showing people how to jump and stuff ,everyone is suprised how easy it is.it's almost a let down! 🙂
Posted : 15/02/2010 12:48 pm
 GW
jenga - open your eyes mate.
picking up the bike, jumping, manualing even whipping is all about keeping flow on the trail.
just the same as planning gear changes, getting out the saddle or timing your pedalling to negotiate a turn would in a road TT.
all these skills can make your ride LESS effort and waste LESS time.
Posted : 15/02/2010 12:51 pm
I'm thinking about getting a new bike but would like to start jumping and riding more downhill trails.
Any suggestions on a bike that would be suitable?
Thinking about spending up to £1200, not sure between long travel hardtail or FS.
I'm leaning towards the Specialized Pitch Comp.
advice and recomendations welcome.
Posted : 15/02/2010 1:02 pm
 jedi
chuck, it's not about the bike
Posted : 15/02/2010 1:04 pm
for 'proper' jumping it IS about the bike.
you can't ride trails on an XC bike.
Posted : 15/02/2010 1:07 pm
 jedi
learning to jump is not !
Posted : 15/02/2010 1:08 pm
Completely and utterly clueless here, would like to be able to do the basic non-terrifying stuff but remain firmly planted on the ground. However, I suddenly seem to have clicked for no apparent reason the most basic move (that everyone else learnt at age 4) of flicking the front wheel up . You don't pull you push! I actually cleared a massive - easily 4 inch! - log on the track recently without getting off / crashing / ending up in an ambulance. Yessssssss! On top of the world for days - Ononeoranges' front wheel in off-ground shocker!
Not sure 1) I could repeat it or 2) I'll be appearing in any rad vids soon.
(Apologies for the rather unseemly enthusiasm!).
Posted : 15/02/2010 1:09 pm
tracknico - maybe others will correct me if this is wrong assumption, but most people here will be wanting to safely hit, clear and enjoy the kind of jumps that crops up in the flow of a singletrack, rather than the vertically-faced kickers from a set of doubles. "trails" is a misleading phrase for most recreational cyclists.
Posted : 15/02/2010 1:10 pm
I agree, learning to jump isn't but I'm buying a new bike and want to make sure it can take the strain and abuse.
Posted : 15/02/2010 1:11 pm
 jedi
chuck, 🙂
Posted : 15/02/2010 1:13 pm
well im sorry to mislead. i was merely suggesting that one would benefit from riding somewhere where the jumps are made to be jumped, and not because the FC guys had got bored and put some lumps in.
in fact i was responding to a guy who siad he wanted to buy a bike to go jumping. to which a more jumping orientated bike would surely be btter suited?
I have a mate who is capable of riding really steep rolling drops, is really fast on singletrack and is dead fit, he cannot seem to land his bike on anything other than the front wheel. Seems this is a common problem.
I'd love to be able to ride the jumps I see on my way down the A3 by the M25 Junction but I think that time has passed so I'm happy to just do the odd 3 footer along the trails.
Posted : 15/02/2010 1:15 pm
 jedi
no he said jump/downhill trails ie a mtb! 🙂
Id love to learn how to ride doubles, so I can ride some trails faster, but the thought of not getting enough air and crashing into the landing ramp scares the beejesus out of me!!!
I can`t get over the fear so cant just hit it for the first time, im sure its just a matter of speed and pushing into the take off... 🙁
Posted : 15/02/2010 1:19 pm
10/10! It seems surprising at first.
I bet I know what that is, and if he stops doing it he'll be even faster on everything else too.
Posted : 15/02/2010 1:20 pm
I think learning on tabletops is the way. Once you can clear a 8 foot tabletop the world is your oyster..
Posted : 15/02/2010 1:21 pm
ok ok, i dont wanna argue about what bike a fella i dont know wants to buy...
but if he's jumping/doing dh trails only, then choice of bike is important.
So any mountain bike is designed for jumping and downhill tails?
With my limited mtb knowledge, I know that is bollocks.
Posted : 15/02/2010 1:22 pm
 jedi
any mtb will do those things yes. a hardtail,a race xc bike, a full dh bike, a 4inch trael fs......
Posted : 15/02/2010 1:24 pm
ok...
Posted : 15/02/2010 1:25 pm
If I go for a little ride in the woods at some point I will go downhill and there is a chance of a wee jump or two. That doesn't mean I'm doing DH or dedicated bike jumping.
thats great glen, but if someone is buying a bike specifically to do those two aspects of your ride, and not for your entire ride, then they may be better off buying a bike that does those parts better.
Posted : 15/02/2010 1:27 pm
 Euro
Sure you can. Jedi says 'it's not about the bike', I prefer 'if the rider can do it, the bike can too'
A XC Marin Wildcat Trail and rider...[img] ?g2_GALLERYSID=b86983469532418e82296a265ed7137a[/img]
I've since got a jump specific bike as the Marin wasn't too keen on the bigger jumps (much bigger).
It's probably worth noting that a good landing is usually nice and gentle and isn't that hard on a bike it's cack handed flat landings that snap frames.
Yes.
I know.
I'm not saying anything different.
What I am saying is that those people that think "trail riding" means sky-high built doubles in jeans around yer ankles and pushing your bike if it is uphill are in a minority. Most people just like going for a ride on what they call trails, and want to be able to jump a little and stay safe and enjoy it.
Posted : 15/02/2010 1:31 pm
ok, grand thats agreed.
i think chuck knows he wants something a bit more solid anyway.
although euro has nicely pointed out that yes indeed in theory if you buy a cheap 'xc' HT that looks a bit small for you, and then slam the seat right down, you can go get jumping crazy to your hearts content.
Posted : 15/02/2010 1:35 pm
The trend is certainly to make the entry level hardtails more over-built. A lot of them anyway. Usually the fork and wheels will be weak spots I guess.
Posted : 15/02/2010 1:46 pm
 Euro
Tracknicko, i'm 6'5" and if you think the xc bike looks small, you should have seen me on my BMX 😆
GlenP, funny you should mention the forks and wheels. The only items I've changed since new. Both upgraded due to breakages. (rear wheel now 48 spoke Halo SAS)
Posted : 15/02/2010 2:01 pm
 jedi
Posted : 15/02/2010 8:26 pm
I eyed a jump up yesterday following scruff....I wish now that I had hit it without thinking, however, I didn't. Now, I don't know if I would have done it. I also bottomed out the suspension too many times yesterday....
Posted : 15/02/2010 8:39 pm
 rjj
Push not pull - I'm guessing this means you push your bike through the jump which in effect causes an upward movement as you go up the "ramp" as opposed to yanking at the bars on take off?
Posted : 15/02/2010 8:44 pm
I am a bit of a scaredy cat but love Danny Macaskill's skills. Gravity defying!
Posted : 15/02/2010 8:48 pm
 jedi
correct plus a couple of other things
 rjj
What about flat jumps, ie just a little ramp and drops? Is it the same then? I always assumed drops where like bunny hops?
Posted : 15/02/2010 8:50 pm
 jedi
drops are simplest.
Posted : 15/02/2010 8:55 pm
 rjj
Just keep riding and weight slightly back?
Posted : 15/02/2010 8:56 pm
You know, Jedi i disagree with you. You say to mark, you can do anything on that bike. And yes whilst i'm sure say Darren berrecloth could ride a scott scale, or a giant anthem through a set of doubles or a road gap, he wouldnt. The bike makes a HUGE difference to how easy it is to clear a jump. Lets take say a set of dirt jumps with steep transitions designed for maximum height. Ride it on a dirt jump bike, then a bike for 4x. Both are good for jumps but the dirt bike will be noticably better. Then do some jumps on a 4x track, and surprise surprise the 4x bike will handle them alot better. Could this be because they are the right tool for the right job?
Posted : 15/02/2010 8:57 pm
 jedi
lyon
the technique of drops, jumps etc.. can all be learned on any mtb,
road gaps, 20ft+ drops etc.. all require specialist bikes. but to learn how/why you can do it on any mtb. dont you agree
Posted : 15/02/2010 9:01 pm
I doagree with you there... But only to a certain level.I think I misunderstood you at first..
Posted : 15/02/2010 9:13 pm
 jedi
by the way, i have never said to mark he can do anything on his bike. i said he can do anything on a bike. and he can
Posted : 15/02/2010 9:15 pm
Go on then?
TBH I think that my jumping skills might be a slightly diff level to a lot of the other people here, but some serious over the bar landings puts a bit of doubt in my mind.
I have been told and learnt about riding off 2's and riding off 4's, ie keeping your arms and legs as distinct parts whilst taking off, and the importance of keeping fluid in the air but it seems that the faster I go the harder it is to keep all this together. I'm talking 25+ foot jumps where crashing becomes a bit more serious. Still if one of you guys reckons you can remove my doubts it could be well worth the cash.
Posted : 15/02/2010 9:22 pm
 jedi
25ft+. yeah no worries
a rotation problem is a rotation problem. size matters not
Posted : 15/02/2010 9:25 pm
Jedi, you're based in the South East right? Where would you suggest for a training session then? I'm based in Oxfordshire.
Posted : 15/02/2010 9:29 pm
 jedi
email me(in profile) if you wish
Posted : 15/02/2010 9:33 pm
i think jedi is selling 'skills' not 'bikes'. if i turned up to a skills session with my short travel 29er hardtail and jedi said 'no sorry mate i cant teach you anything with that bike' i would be pretty pissed off and he would be a crap teacher. from all accounts exactly the opposite happens and that is why he is highly regarded.
Posted : 15/02/2010 9:51 pm
 jedi
what? a 29er.........erm :O)
Posted : 15/02/2010 9:55 pm
Jumping a bike isn't rocket science if you lean back the back wheel will drop, if you lean foward the front wheel will drop, if you pull up or push down the bike will change it's altitude etc. It's all in your mind, If you hit the jump straight in the centre of the bike and relaxed you'll be fine. If you are heading toward it thinking your going to crash you probably will if you don't think about crashing then you probably wont. See if you can get a hold of Dirt fundimentals (Try CRC), it's got quite a few good riding tips on it.
Iain
Posted : 15/02/2010 10:15 pm
it's on my list for this year.
I can ride drop offs ok, couple of feet no issue, any bigger and I start to pucker a bit but that's psychology I think more than any technique thing (I keep getting the thought 'what if the landings a bit heavy and the cranks snap....'). Glenp and his lot taught me the basics there of pushing with your arms and feet to get the bike rotating and so the front wheel goes up.
But jumps still do me in, even though I'm sure the technique is similar / the same. I used to jump Ok as a kid (when you bounce) and cleared a small double with a pit between last year somewhere up by Holmbury on a general XC ride but that was fluke. Or better put - I didn't know it was there, followed another rider on a slightly different line and before I know where I was I was on it with no time to panic or do anything other than 'ride' over it in a nice relaxed trail riding manner. If I'd had time to think about it......
Posted : 15/02/2010 10:27 pm
ok jedi, I dont want to cause offence, and i think we may just disagree with a few aspects of mountain biking... Lets just agree to disagree. At the end of the day everyone on here enjoys riding a bike and that is what matters.
Andy
Posted : 15/02/2010 11:18 pm
oh, a bit of advice, its better to over-clear a jump, than to not clear it in my experience...
Posted : 15/02/2010 11:19 pm
 jedi
lyons, im interested
Posted : 15/02/2010 11:27 pm
It is a relief to see others share my fear of flying.
Getting confident to take features in my stride has become an obsession and I watch this thread with interest to see how others get over it. Truth is that anything I cant ride straight off and demands a bit of commitment sends me hard on the brakes usually resorting in an hilarious spd topple (much to the annoyance of my riding chums who have lost all their flow because of me)
I am slowly building up confidence but it is [i]really [/i] slow.
Tomorrow I am going to try AGAIN to build up the confidence to pop of a tiny root (about a foot drop onto a sleep run-off ). Each time I get to it I chicken out though and it is doing my head in. Going out tomorrow before work; wish me luck
I know if I do it a handful of times it will be on to the next one..then the next one. The holy grail is to take off the brakes, look ahead and just ride it!
Posted : 15/02/2010 11:30 pm
 jedi
be settled before the root drop that you speak of and dont rush to land.
Posted : 15/02/2010 11:33 pm
jedi are you refering to the overclearing? In my experience, if I overjump, it results in a near crash, or at worst a slidey type fall.
Whereas if you say hang up on the front wheel, that results in a trip over the bars, which to me hurst more, you may be lucky and hang up the back, but that can still send you over the bars...
Do you think differently?
Posted : 15/02/2010 11:35 pm
indeed. The problem with this one is that is goes uppishly first and you can only see sky infront of you until the last minute. This puts the willies up me. I can do a similar one with a downward approach and it doesnt bother me at all (the landing is at the same angle as the approach)
 jedi
no andy, the agree to disagree. about what?? i thought we agreed....
Posted : 15/02/2010 11:37 pm
 jedi
dancake, even better. look out, as you approach and ride off it
Posted : 15/02/2010 11:38 pm
oh, about the bikes... Maybe its because i have been lucky enough to ride alot of different types of bikes, so one can feel 'wrong' easilly to me.
P.s, I'm rubbish at putting what i think into words, so alot of what i type doesnt make sense to me either...
Posted : 15/02/2010 11:43 pm
 jedi
pmsl 🙂 high5
Posted : 15/02/2010 11:44 pm
its funny (and sad) really. 2 of my workmates are my ridiing partners who have much bigger balls than me and we have this same conversation.
I usually end up convinced that I am actually [i]brilliant [/i] on my bike and walk around with my head held high knowing that TOMORROW is when it will happen for me.
why am I so scared.? I have never broken anything on my bike (ok maybe a rib) and only went over the bars once. That was going over a big jump I didnt know was there sat on a saddle at full extension.
These days the saddle is down and I move around a lot more. I will be fine, right? I dont have much of a technique..just squash the forks a bit and straighten my arms as the fron wheel comes off....simples?? 🙂
Posted : 15/02/2010 11:49 pm
 jedi
erm not quite
Posted : 15/02/2010 11:53 pm
😀 I still need to get through that jump section at corby though! I'm possibly going to get my wrist x-rayed though, as it still doesnt feel right .It may be a while if its a bad result
Jedi can definitely teach you how to jump. I saw a picture of my friend 'jezkidd' with both wheels off the ground tonight. That is a miracle, I never thought i would see the see the day!
Posted : 15/02/2010 11:55 pm
erm not quite
I knew it!
So could you teach [i]anybody[/i]..even me.
joking aside is it one to one or do you do small groups? 3 of us might be interested...
Posted : 15/02/2010 11:56 pm
 jedi
lyons, i told you i would get him to fly 🙂
i still think you broke your wrist at corby
Posted : 15/02/2010 11:57 pm
Yeah, its good stuff, he was raving about it... I'm looking forward to riding with him again, I'm sure i'll see a difference.
As i said, I'm gonna try to get it x-rayed. It isnt really painful, most of the time it is ok, but hte odd time i've knocked it its hurt for a few minutes. Then i slipped over in the mud earlier and its started doing all sorts of clicky stuff again. Thing is, ive ridden my bike quite alot since, done tons of digging and it seems ok. Surely it would hurt more? It doesnt even hurt now, just keeps clicking.
( sorry for going waaaaaaaaaaaay off topic)
Posted : 16/02/2010 12:04 am
 jedi
worth check ing for sure!
Posted : 16/02/2010 12:06 am
i try to jump off little stuff on rides as much as i can and i can do 2 ft step downs, but thats about it. when i crash doing jumps, its because i am at an angle in the air, and dont think about it until i land, then its too late.
Posted : 16/02/2010 12:08 am
Page 2 / 3
