Can't get my 1...
[Closed] Can't get my 11 speed xt cassette tight ??
Hi,
Have just got a new set of pro 4s and my xt cassette won't tighten even close to enough.
Can't remember if it had a spacer behind if or not. Any help would be great.
Cheers Shaun
Posted : 21/09/2016 8:43 pm
I think Hope use a road free hub on their wheels and these need a spacer for a MTB 11 speed casette which is the same width as a 10 speed .
Posted : 21/09/2016 8:48 pm
Pro4 should have a small spacer when used with an MTB cassette.
Should be included with the hub/wheel.
Posted : 21/09/2016 8:50 pm
Had the same head scratch moment a week back with new shimano freehub and cassette, mine didn't come with the spacer either but it defo needs it as above
Posted : 21/09/2016 9:00 pm
Ok, cheers for that. I will ask the boys at the lbs as they ordered the wheels and set them up tubeless for me.
sure they will have one lying around.
Posted : 21/09/2016 9:01 pm
With hope wheels the spacer should be bundled up with the spare spokes and axle adaptors that come with each wheel
Posted : 21/09/2016 9:16 pm
I installed mine yesterday (also pro4), couldn't get it to tighten up with the spacer so took the spacer off and went for a ride. Was jiggling about loose so I'm thinking that it's a tight fit so might need to give the cassette a bit of a bash to get it to seat up against the spacer and to be able to tighten up the lock ring.
So in short, you need the spacer!
Posted : 22/09/2016 9:54 am
