Cannot get new chai...
[Closed] Cannot get new chain to grip on cassette, driving me nuts!
This problem is bizarre.
Recently changed the chain for a new one as it was looking a bit sloppy. 9 speed shimano XT shifter, shadow type.
New chain on old cassete wouldnt grip, so put on a new 9spd XT cassette. The chain still wouldnt grip.
So put another new chain on, same issue.
Have re indexed the gears, the shifter is in good shape, no real play or slop, it hasnt been bent, but I still cannot get it to take any real power with its jumping suddenly around the cassette.
Completely stumped!!!
Help
please
Posted : 19/10/2015 12:34 pm
Chain too long?
Posted : 19/10/2015 12:35 pm
Tried changing the chainring?
Posted : 19/10/2015 12:37 pm
As above, or maybe the mech is straight but your hanger is slightly out of line?
Does it happen all across the cassette or just top or bottom?
Chainring especially if you're running 1X.
Posted : 19/10/2015 12:39 pm
As above. Also, chain routed correctly through mech?
Posted : 19/10/2015 12:41 pm
 kilo
Another vote for chainring
Posted : 19/10/2015 12:42 pm
sorry numpty question but why would a worn chain ring cause it to jump on the cassette? Chain might be too long but dont think so
Posted : 19/10/2015 12:44 pm
it is a 9 speed chain right?
new bike ๐Ÿ™‚
Posted : 19/10/2015 12:45 pm
yes def 9 speed chain, checked box several times, and changed to a different new chain to make sure, but thats exactly what its like, like its the wrong chain for the cassette
Posted : 19/10/2015 12:46 pm
check mech hanger is tight, is there play in the freehub, is the rear axle broken?
Posted : 19/10/2015 12:49 pm
Yep chainring as above. Had that before, felt like the chain was skipping on the cassette but it was actually skipping on the chainring.
Posted : 19/10/2015 12:50 pm
It will be the front chain ring. I had this recently when I borrowed a newer chain from another bike. It feels like its slipping on the cassette, but its slipping at the front. Same reason as new chain will slip on old cassette, just the front chainring is more tolerant of wear
Posted : 19/10/2015 12:51 pm
I had this issue recently. I changed front chainring, cassette, chain with no difference. It turned out my freehub was failing and would occasionally slip then catch again. It was driving me crazy and I didn't work out what was happening until it got worse and my pedals would spin with no resistance. I'm a little slow though so this might've been really obvious to others ๐Ÿ™‚
Posted : 19/10/2015 12:56 pm
As above, how do you know the chain is skipping on the cassette rather than the front ring ?
Posted : 19/10/2015 12:57 pm
Hooray, collective pat on the back for you guys! ๐Ÿ˜€ Put it into the middle chain ring and rode round the garden and watched closely, right enough its the chain ring! I never even thought to look there just assumed it was the cassette, D'oh!
Thanks very much guys, I only spent two hours trying to figure it out
Posted : 19/10/2015 1:01 pm
Chainring
Could be freehub if it was skipping before you started replacing stuff but since you said your replacement was due to slop......
Chainring
Did anybody say CHAINRING?
Posted : 19/10/2015 1:14 pm
