Just wondering... You can get reverbs in all flavours, I like right hand side mounted under on the left.
I've never seen a left hand xloc button though to mount on the right as a stock item and it's £150 for the part separately..
Looking at a set of xloc forks- wondering if I got a left hand reverb and a right hand xloc if I could swap the 2 remotes to run them under the bars out of the way? I don't think so as you have a floodgate on one and a speed knob on the other, but does anyone know if this can be done?
Don't think so as iirc the fitting are different for the hoses.
I think they'd fit ok but I'm not sure if the action of the two levers are the same, but that could be caused by the mechanics of the fork / lever so it could be worth trying. I've got both reverb and the xloc on the left hand side, both under the bar. A bit cluttered but seems to work ok
The parts manual shows both as totally dissasemblable, so I was hoping I could remove the button and the barb and just swap the bodies over.
Wonder if I say loco 3 times he'll magically appear with the answer?!
