Can you space 150 d...
[Closed] Can you space 150 dual position revs to 140?
 rob2
As title. Can you space down 150/120mm revs to 140/110 with a 10mm spacer?
Posted : 26/11/2011 7:06 pm
For the sake of 10mm I doubt it's worth it tbh.
Posted : 26/11/2011 7:35 pm
No but just put 10psi more in the - than the + chamber and it'll suck them down the 10mm your after
Posted : 26/11/2011 7:40 pm
 rob2
Cheers ๐Ÿ˜‰
Posted : 26/11/2011 7:48 pm
Whyte1 - Member
Dual Position Revs are solo air so that won't work. Just run them as is difference will be minimal
Posted : 26/11/2011 8:15 pm
craigxxl - I were going to say that
they come supplied with plastic spacers though so I'm guessing they can be adjusted..
Posted : 26/11/2011 8:25 pm
 DeeW
They usually come with a couple of 10mm spacers to insert in the air spring: whatever size spacer you add reduces travel and ride height by that much. Lots of instructions on web and on the SRAM site. I've found 15mm plastic plumbers pipe works a treat: just drill a couple of 2mm holes in it for air flow.
Dave
Posted : 26/11/2011 10:45 pm
Appardntly its easy to nktice 10mm
Posted : 26/11/2011 10:52 pm
 flow
It is when you only have 10mm to start with, you should know.
Posted : 26/11/2011 10:58 pm
Aww bless.
Posted : 26/11/2011 11:03 pm
