Can you reuse a Shi...
[Closed] Can you reuse a Shimano chain pin?
I needed to split my chain to swap the front mech, I managed to find the Shimano pin that I used to join the chain initially and used a chain tool to push it back out.
Once I'd swapped the mech I pushed the pin back in place, seems solid enough.
But am I asking for trouble doing this?
Posted : 27/01/2012 9:22 pm
What's the worst that could happen?
Posted : 27/01/2012 9:27 pm
 anjs
no get a powerlink
Posted : 27/01/2012 9:32 pm
+1 power link
Posted : 27/01/2012 9:38 pm
The worst that could happen is that the chain could snap. Annoying but not exactly the end of the world. I'd invest in a SRAM chain (I've only ever used these, right back to when they were Sachs-Sedis) and either change it over now or, if you don't mind doing these things at the side of the trail, pack it in your daysack/Camelbak/seat pack/whatever you use along with a chain tool and swap it over when the Shimano chain gives way.
Posted : 27/01/2012 9:41 pm
Cheers for the replies, I have a spare power-link so will probably change it before I ride next.
Posted : 27/01/2012 9:42 pm
I would, Shimano joining pins are oversized, and aren't supposed to be removed once fitted as they reckon they'll be more likely to fail (probably a different colour so they can be identified as the one not to be touched).
Posted : 28/01/2012 9:08 am
You're supposed to split it at a normal pin and then use the special pin to join it again. Not what you did, the chain will probably fail at the pin you have used. It will fail when you're powering uphill, you will fly forwards and mash your bollocks or knee on the stem!
Posted : 28/01/2012 9:13 am
 anc
Sram chains are overpriced chocolate, they had the edge 10 years ago, things have moved on since.
Posted : 28/01/2012 9:16 am
 cp
As Lucas. I'd be tempted to break it at the same point and put a powerlink in. The shimano rejoining pins are a slightly larger diameter than the normal pins, so once used in a link, you shouldnt take them out.
Posted : 28/01/2012 9:26 am
I did it once...never again.
Posted : 28/01/2012 9:54 am
I have reused them many times because I failed to read the instructions which say they are once only. Never had a problem but I've now gone over to sram chains and their far superior power link system.
Posted : 28/01/2012 10:34 am
I've joined them in the old way...not always reliable.
Sram links are nice but silly money.
Posted : 28/01/2012 11:30 am
 cp
Three quid a pair for the last links I bought a couple of weeks ago from ebc....
Posted : 28/01/2012 12:24 pm
 cp
Double post...
Posted : 28/01/2012 12:30 pm
The worst that can happen is the side plate will split off, jamming in the rear mech, this will inturn damage/destroy your mech hanger, rear mech and possibly rear wheel. You will simultaneously crash, braking your shoulder blade. Due to this work will fire you and you will become jobless and homeless, and your wife will leave you.
I'd put a quick link in now, they're only a couple of quid, really it's worth it. (Split the chain at the same point you split it before, get rid of the outer plates at this point and replace with SRAM powerlink)
Posted : 28/01/2012 1:52 pm
I've removed the Shimano pin and put in a SRAM power link I also shortened the chain as I remembered last night that I've just gone from a triple front to double front, so my outer ring is smaller that it used to be.
Posted : 28/01/2012 2:00 pm
Phew, I was worried about your future for a sec there.
Posted : 28/01/2012 2:23 pm
You will have a "testicular stem interface moment" when it breaks.. ๐Ÿ˜ณ
Posted : 29/01/2012 10:47 pm
ive done it before, it was okay for a get you home type situation.
it snapped the first time i gave it some (real) power though.
(i was seated, and using the big ring when it cracked)
my kids are glad i wasnt standing up to sprint at the time.
Posted : 29/01/2012 11:04 pm
