Can you modify a 2-...
[Closed] Can you modify a 2-position Gravity Dropper to 3 position?
So I can have one setting which is about an inch lower than full-up climbing.
Posted : 05/06/2012 9:15 pm
Yes. It's just a question of dismantling it and drilling a hole where you want it to stop.
However, there have been reports of failures with the 3 hole model. Do a bit of searching before you commit.
Posted : 05/06/2012 9:17 pm
You can buy the multi drop head if you don't want to drill your existing post.
Posted : 05/06/2012 9:31 pm
I had the multi drop version and snapped the inner post at the middle hole the one time I used it. I got a new one on warranty but they basically said yeah you can't really use that middle hole.
Posted : 05/06/2012 9:43 pm
Why would it snap when you use the middle hole? I could understand it snapping there at full extension (greatest leverage and the obvious weak point), but just because the saddle is down a bit and the pin in that hole it shouldn't make any difference.
FWIW I have 3 multi position GD's - the oldest of which is 7 years old and have had no problems. I've only taken it apart and lubed it once and that was because I was curious, not because I needed to!
Posted : 05/06/2012 10:30 pm
boriselbrus - Member
Dunno. I don't understand either, but there are definitely "issues"
Posted : 05/06/2012 10:49 pm
