Can you identify th...
Can you identify this hope hub?
15 Users
1 Reactions
 Tim
Evening all
Looking to convert this hub to thru-axle...albeit I don't actually know what model it is 🙂
Anyone a dab hand at identifying hope hubs?
Cheers!
Tim
Posted : 17/04/2025 8:17 pm
That looks like it might be a hope front hub.
Posted : 17/04/2025 8:24 pm
retrorick reacted
 Tim
I have no idea of why that 1st picture has a massive border...
Posted : 17/04/2025 8:27 pm
https://www.hopetech.com/product-documents/hubs/
Posted : 17/04/2025 8:28 pm
Hope XC/Sport maybe?
If you remove the end caps and look at the bearing sizes it'll give more of a clue.
Posted : 17/04/2025 8:38 pm
 Tim
I think it may be a pro 2 as its a hope hoops wheelset and i think they only came along with the Pro 2...possibly
Posted : 17/04/2025 8:40 pm
 Tim
Posted by: singlespeedstu
Hope XC maybe?
Good idea - will have a look tomorrow
Posted : 17/04/2025 8:42 pm
I've got a Hope Hoops front wheel with a Pro 2 Evo hub, and it says "Pro 2 Evo" on one side. So it may [i]not[/i] be one of those.
Posted : 17/04/2025 8:57 pm
 Aidy
Looks like a Pro 2 to me, but I might be wrong
Posted : 17/04/2025 9:04 pm
As above it is at least a pro 2 as that was the model when hope hoops started. The earliest hope hoops didn't even have it engraved on the hub iirc. Good news is the front hubs have not changed much so pro 4 adapters should fit (Inc the hope boost kit).
Posted : 17/04/2025 10:17 pm
My immediate reaction was 'Pro2'. I had many years staring at one on one of my bikes during Sleeplesses (is that the plural ?) and Mayhems
Posted : 17/04/2025 11:50 pm
Also reckon it's a Pro 2
Edit... I might have some spare adapters too. What size do you want to convert to?
(away at the moment but home next week)
Posted : 18/04/2025 6:17 am
Also going to say pro 2 as they were the version when the hoops were about.
Posted : 18/04/2025 7:06 am
 Tim
Posted by: stanley
20mm I think.  Will stick a vernier over the fork axle to make sure.  Cheers!
Posted : 18/04/2025 8:11 am
Might also have a spare adaptor if required?
Posted : 18/04/2025 9:37 am
Didn’t the Pro2 hub need an internal axle change to run thru axles?
Posted : 18/04/2025 11:52 am
@timbur I think that's only the rear one.
Looks pro2 to me. I've got a nearly identical one and my pro4 adapters fit it.
Posted : 18/04/2025 12:40 pm
I don't think it matters what hub we identify it as. Surely identity is up to the hub itself?
Posted : 18/04/2025 2:28 pm
As others have mentioned, Oro 2 through to Pro 5 use the same adapters.
Pull the existing end caps off and you should see a 20mm ID bearings, if you do, you're golden. If the bearings are smaller, it could be a XC (very unlikely as I don't believe that was ever used for hoops) or is the end caps unscrew from reach other, it would be a BULB (again, not used for hoops as far as I know).
Posted : 18/04/2025 2:54 pm
