Can Pikes be change...
[Closed] Can Pikes be changed from 26" to 650B?
I'm sure I know the answer to this, but I thought I'd ask anyway. Can I change my 26" 160mm Pikes to 650B? In my mind all it *should* need is new lowers but I don't know about fork offset/rake etc and whether all the internal gubbins is the same length.
Anyone know?
Posted : 14/09/2014 10:21 am
You can do this with Fox forks, I know this as I might be doing it. Turns out the only difference is the dropouts and bridge. Sorry if this doesn't help.
Posted : 14/09/2014 2:53 pm
Heard you can change the 26" dual to 27.5...making them 150/120 instead of 160/130. Not sure about offset etc tho.
Posted : 14/09/2014 6:52 pm
If you can find the RS parts pdf you should be able to figure out what is different, at a guess it might just be the lowers. Wouldn't be surprised if the cost of lowers isn't far off what the fork retails for at discount though!
Posted : 14/09/2014 7:12 pm
It's not just the forks you need to check the rear wheel will fit inside frame and for FS still clear on full travel.
Posted : 14/09/2014 7:13 pm
I'm planning on buying a new frame, and it would be nice if I didn't have to buy a whole new fork as well.
Or maybe I'm planning on making a "67er".
Posted : 14/09/2014 7:51 pm
So from the spare parts catalogue ( https://sram-cdn-pull-zone-gsdesign.netdna-ssl.com/cdn/farfuture/_vsHOKraQvVdZbP1gLbC3gOoYniUOjbJv1kegx6C93w/mtime:1383143110/sites/default/files/techdocs/2014_rockshox_spc_rev_a_0.pdf), it looks as though [i]everything[/i] has its own parts number. Whether or not that translates to physically different parts, I don't know.
I.e. there is a different parts number for the lowers, uppers, air spring, damper for each of 26/650b/29.
I think mather01 is right though - the 26"/160mm air spring shares a parts number with the 27.5/150mm.
Posted : 15/09/2014 1:07 am
Anything with a different PN is a different part - where shared, they use the same code.
IIRC it doesn't work out anything like cost effective to swap bits around to change wheelsize
Posted : 15/09/2014 7:55 am
the air springs are definitely interchangeable as they say on them the travel at each wheel size
Posted : 15/09/2014 9:53 am
