Can my kinesis maxlight frame be modified to use tapered forks by changing the heatset? Its 7 years old frame so standard from 7 years ago.
There was no single standard even 7 years ago. If it has a straight 44mm headtube it can be done.
Depends on what headtube it has. If it's the old 1 1/8th standard with external cups pressed into the frame, then no. If it has integral cups that are pressed into the frame with only a little bit exposed, then it's possible to fit a different bottom cup that will fit tapered forks.
Can't guarantee that though, headsets are complicated things.
mrajb52
Sorry to hijack ure thread but I've got some white forks off a carrera blast if you're interested !,£20 + postage !,ping me an email if you're interested.
Thx Simon
