can i fit tapered f...
[Closed] can i fit tapered forks to a non tapered head tube??
As title really Im looking at getting some new forks for my pitch and most of the good deals are with tapered forks??
is there a headset conversion or something that will allow me to fit this type of forks??
cheers
steve
Posted : 07/12/2011 9:45 pm
No.
Posted : 07/12/2011 9:46 pm
Maybe.
Forks tapered 1.5" to 1 1/8 will fit in non-tapered 1.5 headtube (with an adapter at the top) They won't fit into a 1 1/8" headtube though (unless you use an inverse shim)
Posted : 07/12/2011 9:49 pm
 jedi
no
Posted : 07/12/2011 9:50 pm
the answer is yes if its a 1.5" headtube
Posted : 07/12/2011 9:59 pm
ah pish !!! back to the drawing board then....
im after a set of 150/160mm air forks normal steerer and 20mm front hub.....
suggestions please, new or used !!!
Posted : 07/12/2011 10:00 pm
 jedi
a pitch aint 1.5
Posted : 07/12/2011 10:04 pm
Revelations have been superb on my five, 20mm maxle and air + and neg. Survived a battering at home and abroad.
Posted : 07/12/2011 11:27 pm
I thought you could fit one to an internal headtube with an adaptor headset thingy.
Posted : 08/12/2011 1:03 am
cant you have the 1.5 steerer pressed out and a 1. 1/8 one made up and pressed back in, as you say some stoming deals on the tappered type, money saved could go towards that, of course use a good eng comp ๐Ÿ˜€
Posted : 08/12/2011 1:10 am
I have a tapered headtube ๐Ÿ™‚
Where are these storming deals???
Posted : 08/12/2011 6:10 pm
Right here!
As long as you want some 180mm RS Domain 318s in white ๐Ÿ™‚
Posted : 08/12/2011 6:30 pm
http://www.ebay.co.uk/itm/2011-FOX-FLOAT-32-SERIES-RLC-FIT-MTB-FORK-15MM-AXLE-150MM-TRAVEL-/360415550506?pt=Cycling_Parts_Accessories&hash=item53ea70dc2a
I just ordered some 160mm tapered vans from the same seller so I will let you know when they arrive, if you were interested in ordering from him. Sam
Posted : 08/12/2011 6:39 pm
