Can Hope2 front hub...
[Closed] Can Hope2 front hub on QR fork be made more secure?
I do not want to splash out on bolt through forks, but do want to investigate how a Hope2 front hub on a QR fork can be made as secure as possible.
Is there some sort of superstar hub thing I can use or DTswiss skewer?
Currently use Shimano QR. Many thanks for any thoughts.
Posted : 25/04/2011 9:32 pm
 igm
They do a 9mm bolt through conversion I think - but you'll need the bolt to go with.
Posted : 25/04/2011 9:34 pm
I changed mine over to the DT skewer. The bits for the hub cost about £20, the skewer around £50. Made quite a difference and money well spent I think !
Posted : 25/04/2011 9:35 pm
 gamo
Superstar also do a 9mm front qr,my brother fitted this to his and made quite a difference.
Posted : 25/04/2011 9:38 pm
Do you mean more secure - as in safe from theft, or more stiff? If the former, then there are lockable skewers available - e.g. Pinhead.
Posted : 25/04/2011 9:44 pm
Not the theft angle, it's the Pinder issue I worry more about. Stiffness would be good too.
Posted : 25/04/2011 9:53 pm
Ah. For the "Pinder" problem, try tying a knot in your hanky.
Posted : 25/04/2011 9:59 pm
Paranoid android !
Posted : 25/04/2011 10:29 pm
9mm bolt-through isn't any more secure than QR though. Shimano QR is about as good as it gets for QRs, Halo do a nice bolt-in for standard QR wheels but I'm not that convinced it's more secure than a QR. The DT one if I understand how it works correctly should be less likely to come loose than a normal QR, until it breaks.
For the Pinder problem, the solution is to tighten it up right in the first place, and be a wee bit aware of the condition of your bike so that you actually notice the thing coming loose before it escapes, if it ever does, which it probably won't.
Posted : 25/04/2011 10:56 pm
exactly what he said
Posted : 26/04/2011 2:08 pm
